I want to convert old vhs tapes so that i can burn dvd as backup and put on qnap storage device to look at on ipad , family can log onto qnap and look on my tv.
My set up is vhs composite to sony tr460 to fireware connector to win 7 64 laptop
From my reading on this forum :
Vurtual dub with lagarith making avi file then handbreak to mp4 file conversion then send to qnap, find way to burn a dvd ?.
Does this sound good or any other suggestions will greatly be appreciated
Thanks all for your help
No. If the goal is to create a DVD playable in DVD players, then you don't want to create an intermediate MP4. You'd want to go directly from Lagarith to DVD, perhaps doing some editing and filtering on the way. Maybe take your Lagarith AVI and feed it into AVSToDVD.
If all you want is to burn that MP4 to DVD as a data disc, then that's something else, but I don't think that's your intent. Or take the Lagarith AVI and make both MP4 and DVD. -
If you want to go down the vdub/lagarith route you can not use your camera/firewire setup. Vdub can capture with these but you end up with a DV.avi just as you would using WinDV
You can still use handbrake to convert to mp4. DVD creation can be done with avstodvd and imgburn for the actual burn to disk.
To use lagarith you would need at the very least a usb capture device such as a Hauppauge USB-Live2. Avoid cheap devices since results are variable. -
nubie help vhs to trv740 to laptop need best process/format for my needs
By Nickv48 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 28th Jul 2020, 09:07 -
Convert VHS tapes to DVD, High quality
By lakkantha in forum Capturing and VCRReplies: 16Last Post: 25th Aug 2018, 13:35 -
Is H.264 a good format to convert VHS to?
By RyfromNy in forum Video ConversionReplies: 2Last Post: 17th Mar 2017, 04:21 -
HR-S2911U jvc vcr. Any good for capturing old vhs tapes?
By ThreePeak in forum Capturing and VCRReplies: 6Last Post: 15th Sep 2016, 13:37 -
Help I'm trying to convert some VHS tapes to DV then save them on my PC
By BirdDaddie in forum Capturing and VCRReplies: 10Last Post: 18th Jan 2016, 01:57
