Hi,
Ok so the panel of my LED tv (Samsung UE32j5500) got damaged, and shows two noticeable impacts. I then by chance found the exact same tv (used) for a cheap price. But with that one the backlight seems to be very low. The settings of both sets are exactly the same but the one I just bought is much less bright in comparison, with duller colors, and has some slight clouding in one of the corners.
So my question is, can I just take the panel of the tv with the backlight issue to replace the panel of my original tv (which works perfectly apart from the two impacts)? Will it fix the issues I'm having?
Thank you.
can't select higher than 16b 48k in Control Panel-Win 7/64
By clashradio in forum ComputerReplies: 8Last Post: 26th Nov 2019, 19:54 -
Win 10 control panel
By Jomapil in forum ComputerReplies: 8Last Post: 20th Aug 2019, 07:31 -
Panel type
By kyrcy in forum ComputerReplies: 2Last Post: 15th Jul 2018, 04:06 -
Sony Bravia LED TV
By Rajeev Hasamnis in forum Video ConversionReplies: 4Last Post: 17th Mar 2017, 23:07 -
Problem with Nvidia control panel in my new laptop
By Stears555 in forum ComputerReplies: 5Last Post: 10th Aug 2015, 03:30
