Try DVDFab and copy Ultra HD Blu-rays and DVDs! Or rip iTunes movies and music! Download free trial !
  1. Hi guys I have adobe preimre/after effects
    I would apperciate if you can help me to know how can I create the effects they added to the title at the very first second on this video
    https://www.youtube.com/watch?v=GclJg7RSp6M
  2. The effect on the title appears to be a smaller version of the overall transition effect.
    Here's a good tutorial on how to create custom transitions.
    https://www.google.com/search?client=firefox-b-1-d&q=create+custom+transitions+in+prem...D9PwPmtG7wAE24
    To replicate the video you showed, you would go into the transition timeline you built from black and white elements in the tutorial, apply the built-in venetian blind effect to the top layer, and rotate it 45 degrees.
  3. It's just a venetian blinds transition effect. I don't have the Adobe products, but most competent NLEs include dozens of transitions, and most of them are customizable. The attached file show this transition using Magix Vegas. I created this just now in about ten seconds.
