Hello all,
I have found already a million topics around this but nothing works so i am going to try here.
I convert my movies to MKV files with MKVMerge program(movie & subtitles in Dutch since i am from Belgium). I than put them on my Cisco NAS and stream them to my Samsung TV.
The movies play correctly but i dont have the option to rewind, fast forward or even pauze and if i start looking at a movie and half way i am going to bed than i have to watch it also from the beginning again.
Anyone who can help me out on this because i am getting frustrated and tried already a million things, nothing works.
Killshaak
Results 1 to 23 of 23
All those functions are built into the media player. If you are using the media player in the Samsung TV, it should be able to fast forward and pause (my 10-year old Samsung certainly can do this). Doesn't your remote have the <<- and ->> or <- and -> buttons on it?
You could also use an external media player and feed its output into the TV via HDMI. -
They are also in a sense built into the compressed file...or not. (shorter) GOP length, Closed vs. Open GOPs, Chapter markers @ the I- or IDR-frame. Indexing & Streaming-friendly ordering. These can all improve the playback features experience.
Scott -
In mkvmerge add these command lines in muxing/add command line options --engage no_cue_relative_position --engage no_cue_duration --disable-track-statistics-tags and check the save as default for new jobs.You will have to remux the affected videos,try this for one mkv to see if it helps.
those add command lines, i dont have them all in that list
Also when i try to add them manually see second print screen and i try to mux than i get errors, see third print screen
[Attachment 54274 - Click to enlarge]
[Attachment 54276 - Click to enlarge]
[Attachment 54275 - Click to enlarge]Last edited by Killshaak; 29th Jul 2020 at 06:17.
When you watch a video that your Samsung TV reads from a file via the USB connection, or via the network connection, your TV is acting just like your computer, except that the Samsung has a media player built in.
If you have a small file size video file that won't let you fast forward and rewind, and can post it on a media sharing site, I'll try playing it on my Samsung TV and see if I can come up with an idea of what's going on. -
btw i also use MKVToolNix and MKVMerge, what is actually the difference? Am i missing something?
As I said in my response to your PM, there is no need to send me private messages, and I don't do free, private consulting. Ask your questions here, and you will get the benefit of having dozens of people look at your questions. Many of these people know far more than I do about media players in TV sets.
Well so far the answers didn't solve my issues so more feedback is welcome on how to solve this
btw i also use MKVToolNix and MKVMerge, what is actually the difference? -
no all the MKV files dont allow it. basically the buttons Pauze, fast forward and rewind are greyed out as you can see on my photo
And what is the actual difference between those than? MKVToolNix and MKVMerge?
All my movies were made in the first place with MKVToolNix and than i started using MKVMerge since i found info that this could solve this issue but still same problems.
[Attachment 54310 - Click to enlarge] -
They're the same thing. Don't they look the same when you open them up ?
I'm talking about mkvmerge and mkvtoolnix being the same thing.
well i see a slight difference between both
[Attachment 54313 - Click to enlarge]
Streaming directly from PC to tv works fine but yeah than i can fast foward and rewind on PC itselfLast edited by Killshaak; 31st Jul 2020 at 15:04.
I did some other tests today, put an MKV file on an USB stick and played that on the TV. That works fine so i think it's related to the Nas(its a old Cisco NSS322 smart storage system which is 10 years old already maybe even older) so guess the issue is on that since USB stick doesn't give any issues on TV.
I fixed this problem last night, I hope it works for you:
https://forum.videohelp.com/threads/401370-I-fixed-Fast-Forward-Rewind-NOT-working-on-...er#post2615871 -
Not appear video virtualdub2 fast forward
By media in forum EditingReplies: 2Last Post: 10th Feb 2020, 02:12 -
Mitsubishi VCR - Can Only See Picture in Fast Forward or Rewind or Pause
By digicube in forum Capturing and VCRReplies: 2Last Post: 28th Jun 2017, 21:53 -
why won't this disc fast forward?
By DaneClark in forum Authoring (DVD)Replies: 9Last Post: 18th Jun 2017, 19:01 -
Ripped&transcoded video freezes and pixelates when I try to fast-forward.
By Nossty in forum Newbie / General discussionsReplies: 4Last Post: 5th Jun 2017, 11:03 -
Mitsubishi VCR HS-U748 rewind/fast forward problem
By davexnet in forum Newbie / General discussionsReplies: 7Last Post: 11th Mar 2016, 17:34
