Hey everyone,
So I'm using Pinnacle for Dazzle to transfer all my old vhs tapes to dvd. The problem I'm having is I believe that they're all just to big to fit on dvd. After I convert them to dvd they end up being about 7 to 9 gbs. I'm fairly new to the digital world so I don't know what to do here. Whenever I attempt to transfer to DVD, thinking Pinnacle would just shrink it down and transfer it to dvd it doesn't seem to work. After the project ends, I get about half way through the dvd and it freezes. I've already wasted a few blank dvd's so I don't want to keep going until I have a better idea of what I'm doing.
Are there any other programs maybe I should be using to shrink the size or should I maybe be editing the videos once I get them to my computer and use 2 dvd's per VHS?
I appreciate your help.
Have a great Day!
				Results 1 to 16 of 16
	Yeah sorry about the lack of info. I have no clue about the bitrate pinnacle uses I just used all the defaults the program came with. There's no real instructions with this program unfortunately. It's pretty complicated for a newb like myself
	Capture the video then use AVStoDVD to make the DVD. It is good at optimizing the results,
 chooses the best bitrate to fit your stuff on the disk.
 Why did you waste some disks? Surely you checked the result before attempting to burn it?
 The burn program should have told you it was too big to begin with.
 Everything should be discrete steps. You capture the video. Check it and make sure it's good.
 You create the DVD output, either video_ts folder or ISO. You play it back on the computer to make sure
 it's right.
 Then you use something like IMGBurn to write it to the DVD.
	I did check the result and everything looked just fine, other than the size and it didn't tell me it was too big. But just froze up about half way through. Thought maybe it was just the cheap DVD's the came with the dazzle. who knows. One said at the very end, "there was a problem closing the DVD"
 But I will definitely take your advice and install those two programs and make sure they are no more than 2 hours long. Thanks for all your help Dave!!
	If your disks are dual layer they can hold 8.5GB.
 Single layer 4.5 (approx)
	I do have some dual layer discs that I got a long time ago.... But I could never get them to burn for some reason. Do you have to have a specific burner? Mine's an ASUS BW-1281ST a.
 Suppose to be a Blu-ray burner I dunno.
	A few questions and recommedations.
 What format is your captured file? Install and run MediaInfo and post the full text of what it reports. Your video may be Mpeg-2 which can be burned directly to a DVD or another format that requires conversion.
 Do you really need to burn a DVD? Are you planning to play your videos on a standalone DVD player? If not, you can place into an .MKV or .MP4 container without any conversion or loss of quality.
 If you do need to have a burnt DVD, don't use the blank DVDs you received with your device. The only quality blank DVDs are Verbatim AZO or Taiyo-Yuden. Everything else, including your free discs are 2nd tier or worse. Not worth using. Taiyo-Yuden discs are hard to find and expensive. Verbatim AZO (be sure it has the AZO logo) is available at Amazon: https://www.amazon.com/Verbatim-DVD-R-4-7GB-Recordable-Media/dp/B00081A2KY/ref=sr_1_3?...%2C1758&sr=8-3
 Your burning problems are either bad discs or bad burning software. Only use Imgburn for disc burning.
 As recommended, AVSTODVD will help make your file compatible for burning, but you'll lose quality if you shrink it to a single layer disc.
 Report back with your info and I and others will be able to help you better.
	A 90 minute video using the highest max bitrate legally compliant on a dvd would only get to 6.6GB, so you must be setting something wrong, encoding-wise.
 And, to clarify what davenext wrote:
 Is not just "generally" but ALWAYS, INVARIABLY, 100%. A formula & a RULE.Code:Filesize = bitrate * runningtime
 Perhaps you can share what settings you chose...
	Thank you Lingyi, Here's the info you requested. We do want the on DVD, although .MKV and .MP4 is probably also a good idea. As I said earlier I do have some double layer dvd's, but can never seem to get them to work. Memorex. I don't know if it's because they're just crap DVD's or the wrong kind of Burner. I also have some Blu-ray discs. Doubt I could use those though. Like I said, total newb to the whole video conversion thing. Thanks again for all your help guys.
 General
 Complete name : C:\Users\Beau\Videos\1994 Our German Affaire Christmas Party\1994 Our German Affaire Christmas Party.mpg
 Format : MPEG-PS
 File size : 3.53 GiB
 Duration : 1 h 20 min
 Overall bit rate : 6 293 kb/s
 Video
 Format : MPEG Video
 Format version : Version 2
 Format profile : Main@Main
 Format settings : CustomMatrix / BVOP
 Format settings, BVOP : Yes
 Format settings, Matrix : Custom
 Format settings, GOP : M=3, N=15
 Format settings, picture structure : Frame
 Bit rate mode : Variable
 Bit rate : 5 944 kb/s
 Maximum bit rate : 8 000 kb/s
 Width : 720 pixels
 Height : 480 pixels
 Display aspect ratio : 4:3
 Frame rate : 29.970 (30000/1001) FPS
 Standard : NTSC
 Color space : YUV
 Chroma subsampling : 4:2:0
 Bit depth : 8 bits
 Scan type : Interlaced
 Scan order : Top Field First
 Compression mode : Lossy
 Bits/(Pixel*Frame) : 0.574
 Time code of first frame : 00:00:00:00
 Time code source : Group of pictures header
 Stream size : 3.33 GiB (94%)
 Color primaries : BT.601 NTSC
 Transfer characteristics : BT.601
 Matrix coefficients : BT.601
 Audio
 Format : MPEG Audio
 Format version : Version 1
 Format profile : Layer 2
 Bit rate mode : Constant
 Bit rate : 224 kb/s
 Channel(s) : 2 channels
 Sampling rate : 48.0 kHz
 Frame rate : 41.667 FPS (1152 SPF)
 Stream size : 129 MiB (4%)
 This is just with whatever the default settings are for Pinnacle for dazzle if that helps any.
	Haven't captured or burned anything in years, but nothing I can see that's a red flag in your video.
 This video will easily fit on a single layer DVD which holds a max of 4.38GB, but best to keep your burns to ~4GB as the outer edge (DVDs are burned from the inside out) are prone to errors.
 Also post the MediaInfo log of the larger file. A dual layer DVD can hold a max of 8.75GB, but again, keep it below ~8GB to be safe.
 Try creating an .ISO (which is a disc image that can be later burned to a DVD) and report if there are any errors. Post the Imgburn log that will show what caused the error. If the .ISO completes, open it in VLC and Potplayer where it should play through without any issues. When you're ready to burn your .ISO to disc, use only Verbatim AZO or Taiyo Yuden discs as I mentioned above.
 Finally, give the make models of the drives you have as it's unlikely, unless they're really old, they can't burn dual layer discs and AFAIK, all Blu-Ray burners can burn SL and DL DVDs.
	Awesome! Thank you Lingyl, I'm still in the process of transferring the tapes to digital to my PC. Once that's done I'll convert to .ISO then DVD as suggested. Hey thanks again for all your help. I''ll get back to you if I have any further issues!
	I slightly uncouth method I tried: I recorded and encoded a video at the highest settings (I believe the 9.8 MPbs, variable bit rate, two pass). Come out at about 7 GB.
 I authored it to a dual layer DVD then I used DVDshrink to shrink it to a single layer DVD as I needed to send it around (this was pre-YouTube days) and I could not see a real difference between the two in a CRT TV or earlier LEDs/flatscreen.
 I never watched them on anything bigger than 32 inch to be fair and they were 4:3 encoded.
 I have not attempted it again on a larger screen or a different, more madern MPEG2 encoder (though I doubt that would make a difference).
 This is all not massively relevant I know but I figured I would mention it.
 PS: DVDShrink can also shrink ISOs
  Transferring VHS to DVDBy jbur in forum Capturing and VCRReplies: 6Last Post: 21st Feb 2020, 01:05
  Converting DVD to MP4 backup file but subtitles not transferringBy idreos in forum DVD RippingReplies: 1Last Post: 30th Apr 2019, 17:11
  Oversaturation when transferring to VHS to DVD, TV Only computer looks fineBy guayabito in forum Capturing and VCRReplies: 7Last Post: 21st Oct 2018, 12:11
  Transferring files to computer from finalized DVD discBy Mikey8s in forum Newbie / General discussionsReplies: 8Last Post: 3rd Feb 2018, 15:13
  Transferring S-VHS Tapes to a PCBy smbecket in forum Capturing and VCRReplies: 6Last Post: 19th Nov 2017, 17:58
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
