I made a rip of a DVD using AnyDVD. I want to make sure that if I recorded it to a DVD and played it on a standalone player, it'd be fine. How do I check that? The problem is -- the VIDEO_TS plays fine in latest VLC but when I load it in PowerDVD 5 or 9 the menus aren't clickable... I don't know which software to trust. I can't just record it into a DVD and try it in a standalone DVD player because I don't have access to one.
I tried making the rip with DVD Decrypter and got the same result. The log doesn't show any errors.
(If it's important, I'm actually not interested in the 1-1 copy, but rather in my custom job that added some subtitles to it as per the guides in this forum -- again it plays fine in VLC but menus aren't clickable on PowerDVD 5/9.)
Operating system: Windows 10.
Results 1 to 10 of 10
I've would tend to trust PowerDVD more than VLC as to how a stand-alone DVD player would react as I find VLC to be more relaxed in handling non-compliant DVDs than PowerDVD.
Personally I test using PowerDVD v7 together with PgcEdit and DVDRemake which both will flag transgressions of the specifications for a video-DVD. -
Ok. But there is both a folder named Video_TS and a file with the same name in that folder.
Of course if you have burnt the folder to a disk you just select the drive letter.
And before I posted I also checked directly running the file in vlc and menus were inactive. Only became active loading the folder. But menus should also be active if you chose to run the ifo rather than the vob -
What you said made me try something that I think has fixed it. I was opening the DVD in PowerDVD (and VLC) by drag'n'dropping the folder. Seems that's not what you should do. I now opened it using the "open" function in PowerDVD and the menus load fine. Thanks!
(However, my newly added subtitle track, which plays fine in VLC, in PowerDVD when I select it I just get a copy of a previously existing subtitle track. Sigh.) -
Did you 'turn on' those new subs? You can't just add them and expect them to behave like already existing subtitle tracks. Did you add them to the DVD by doing something similar to the Method 2 here:
https://forum.videohelp.com/threads/277950-How-to-add-new-subtitles-to-an-existing-DVD
Make those subs available for use in the DVD by doing this:
https://forum.videohelp.com/threads/277950-How-to-add-new-subtitles-to-an-existing-DVD#post1685800 -
I followed that guide, yes. But I misread your post about activation, that's where I messed it up.
4K Player won't play extras/supplements - plays the movie fine
By hotsplice in forum DVD & Blu-ray PlayersReplies: 3Last Post: 9th Jun 2020, 21:42 -
Easy Capture Device Jitter on Tape Play Back VHS or Bata But DVD works fine
By Jromeot@gmail.com in forum Capturing and VCRReplies: 5Last Post: 20th Mar 2020, 18:11 -
Strange file, doesn't play on PC, fine on USB player, wrong field order?
By Killer3737 in forum Newbie / General discussionsReplies: 9Last Post: 1st Mar 2016, 18:14 -
Bluray drive wont load particular disks while other disks play fine
By archie134 in forum Newbie / General discussionsReplies: 5Last Post: 19th Jan 2016, 05:50 -
Authored & burned disc plays choppy in Pioneer player, fine on PS3
By Bruce/Fl in forum Authoring (Blu-ray)Replies: 12Last Post: 8th Oct 2015, 09:13
