1. How can I setup automatic profiles relative to video resolution and FPS?
Example:
If video resolution is equal to or greater than 1280 x 720 and less than 1920 x 1080, use profile "720p30."
2. How can I properly integrate shaders?
I added Anime4K and FSRCNNX to %appdata%/roaming/mpv.net/shaders.
I tried the following lines in mpv.conf:
a.b.Code:glsl-shaders="~~/shaders/Anime4K_Denoise_Bilateral_Mode.glsl;~~/shaders/Anime4K_DarkLines_HQ.glsl;~~/shaders/Anime4K_ThinLines_HQ.glsl;~~/shaders/Anime4K_Upscale_CNN_M_x2_Deblur.glsl"c.Code:glsl-shaders="~~/shaders/Anime4K_Denoise_Bilateral_Mode.glsl;~~/shaders/Anime4K_DarkLines_HQ.glsl;~~/shaders/Anime4K_ThinLines_HQ.glsl;~~/shaders/Anime4K_Upscale_CNN_M_x2_Deblur.glsl;~~/shaders/FSRCNNX_x2_8-0-4-1.glsl"d.Code:glsl-shaders="~~/shaders/FSRCNNX_x2_8-0-4-1.glsl"a seems to only partially work. The result is different from what the author's screenshot at the bottom of this page displays. Neither b, c, nor d work at all.Code:glsl-shaders="~~/shaders/Anime4K_Denoise_Bilateral_Mode.glsl;~~/shaders/Anime4K_DarkLines_HQ.glsl;~~/shaders/Anime4K_ThinLines_HQ.glsl;~~/shaders/Anime4K_Upscale_CNN_M_x2_Deblur.glsl" glsl-shaders="~~/shaders/FSRCNNX_x2_8-0-4-1.glsl"
3. How can I eliminate judder resulting from playing, for example, 24 FPS video on 60 Hz monitors or televisions?
1. Add this to your conf
2. Did you try the workaround given in anime4K instructions? if not try changing gpu-api to OpenGL or Vulkan (There should be an option in mpv.net interface).Code:ytdl-format=bestvideo[height<=?720][fps<=?30]+bestaudio/best
if not there, add this
orCode:gpu-api=opengl
3. Enable display resample under video sync options in mpv.net interface or in mpv.confCode:gpu-api=vulkan
.Code:video-sync=display-resample
If still not satifised with the results, add this to mpv.conf:
. There are many tscale (interpolation) filters, experiment with them as per your taste.Code:interpolation=yes tscale=oversample
Interpolation is not usually recommended since many interpolation algorithms tend to mess (blur or occasionally artifacts) original video IMO. Oversample is only one i found to have least problems for my eyes, as it doesn't affect perceived fps and the easiest to compute. That being said, interpolation is extremely based on personal taste, so be sure to test various filters as per instructions in mpv manual, if you are going down that path. -
1. Could you elaborate?
That is my current config. I want to add the following automatic profiles:Code:input-default-bindings = no input-ar-delay = 500 input-ar-rate = 20 keep-open = yes keep-open-pause = no osd-duration = 2000 osd-playing-msg = '${filename}' script-opts = osc-scalewindowed=1.5,osc-hidetimeout=2000,console-scale=1 screenshot-directory = '~~desktop/' hwdec = yes glsl-shaders = "~~/shaders/Anime4K_Upscale_CNN_L_x2_Denoise.glsl;~~/shaders/Anime4K_Auto_Downscale_Pre_x4.glsl;~~/shaders/Anime4K_Deblur_DoG.glsl;~~/shaders/Anime4K_DarkLines_HQ.glsl;~~/shaders/Anime4K_ThinLines_HQ.glsl;~~/shaders/Anime4K_Upscale_CNN_M_x2_Deblur.glsl" # Editor [protocol.https] osd-playing-msg = '${media-title}'
I want to use different settings and shaders for each automatic profile. I am trying to imitate madVR's profile auto select rules feature.Code:a. If video resolution is less than 1280 x 720, use profile 480p30. b. If video resolution is equal to or greater than 1280 x 720 and less than 1920 x 1080, use profile 720p30. c. If video resolution is equal to 1920 x 1080, use profile 108030.
2. It is working now, though I did not change anything as far as I know, but I discovered inconsistencies between my old and new computers and video resolutions. Anime4K works with any GPU API and video resolution on my old computer, which has a Q6700 and GTX 1060; but it causes videos to green screen at some video resolutions when I use d3d11 on my new computer, which has a Ryzen 9 3900X and RTX 2080.
3. Okay, I will experiment with it.
mpv.net media player
By stax76 in forum Software PlayingReplies: 91Last Post: 2nd Jan 2024, 06:03 -
How to use 'mpv -vf=pp' ?
By Selur in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2020, 10:08 -
mpv and saving
By natty in forum Newbie / General discussionsReplies: 5Last Post: 4th Jan 2018, 05:12 -
Mpv configuration
By hisaishi in forum Software PlayingReplies: 4Last Post: 6th Jun 2017, 18:17 -
VO in mpv?
By fighuass in forum Software PlayingReplies: 1Last Post: 26th Feb 2017, 08:58
