I wish to be able to edit srt files residing on my local network N.A.S. Subtitle edit opens the srt fine but will not open the video.
What am I missing, is there a way to open the video file?
Thanks for any help.
Are you using a mapped (drive letter) network share? For example "N:\folder\filename.ext" vs. "\\Server\folder\filename.ext". If the latter try the former.
Thanks for the reply. I am indeed using a mapped network share. The latest Subtitle edit update 3.5.16 behaves the same. I tried opening the video before the srt, the same. The work around is to copy every thing to an onboard HDD. Such is software life!
Upon further investigation it seems that some setting, which I cannot find in subtitle edit is preventing video display. The window opens and closes normally.
I have an older version, 3.3.7 rev. 1971. It has no problems showing videos on network shares. Both directly via network address and via a mapped drive (Win10).
Thanks for your suggestions. After more looking I set video player under subtitle edit\options\settings\video player to MPC-HC and all is fine. DirectShow (quartz.dll) must be damaged so I'll run sfc
Subtitle Edit Generating Blank srt with timestamps
By aoife in forum SubtitleReplies: 1Last Post: 6th Nov 2018, 12:37 -
Pixelated and laggy video on Subtitle Workshop and Subtitle Edit
By Valerc in forum SubtitleReplies: 5Last Post: 15th Jul 2018, 12:37 -
By Valerc in forum Newbie / General discussionsReplies: 2Last Post: 13th Jun 2018, 15:15 -
How to export a video in Subtitle Edit
By charrua1 in forum Newbie / General discussionsReplies: 2Last Post: 17th May 2017, 16:54 -
Subtitle edit sub to srt blank txt
By field3d in forum SubtitleReplies: 5Last Post: 13th Sep 2016, 12:39
