Hi,
I understand that the correct channel naming for 5.1 layouts is: FL, FR, FC, LFE, SL, SR. The last two being "surround", not "back". It's 7.1ch that adds the back channels as BL and BR (or whatever letters are the standard). SL and SR are actually in the "middle" and the added two in 7.1 are placed at the back. Like this diagram. Everything makes sense and we're happy.
BUT, in the old days the common belief was that 5.1 had the "back" channels (BL and BR in the above diagram) and 7.1 added the "side" ones (the word "surround" didn't appear at all). Idk if that was some kind of old standard before the advent of 7.1 or it was wrong all along.
Thing is, some programs still carried the old standard into the era of the "surround" naming convention. Back when I made my own BD remuxes I had quite a lot of discs with LPCM 5.1 which I converted to FLAC. I don't remember which program(s) I used, ffmpeg, foobar probably, but all my FLACs ended up as "L R C LFE Lb Rb". Those last two should really be "Ls Rs". Assuming the program(s) didn't mess with the channels order then it isn't a real issue, the layout is correct, but is there a way of renaming the channels? If I re-encode the FLAC the channel layout carries along and I don't see how to alter it.
Nowadays I convert all LPCM with eac3to which writes the proper channel data as "L R C LFE Ls Rs".
You got it reversed.
Originally, it was L C R S (surround), w/ surround as center back, immedately opposite C. Like a cross.
Then L C R Ls Rs (left & right surround), w/ surrounds as 15-45degree back of sides (usu. 30). So whereas the the front arc between L & R was 60-90degrees, the back arc was ~120.
This stayed this way until 6.1, 7.1 made it confusing.
Will a JVC VCR "Stop" Playback if the video is "too grainy" or degraded?
By timepassenger in forum Capturing and VCRReplies: 8Last Post: 2nd May 2020, 08:17 -
Why x264 "placebo" preset produce bigger file than "very slow"?
By aleaksunder in forum Video ConversionReplies: 21Last Post: 2nd Mar 2019, 08:25 -
DVD "fake" 5.1 DTS is actually stereo... how to fix empty channels?
By Sapito in forum AudioReplies: 1Last Post: 3rd Jan 2019, 05:31 -
MP4 1080p Rips Playing Back with "Juddery" Panning (Jitter/Stutter)
By orionsbell in forum DVD RippingReplies: 5Last Post: 27th Apr 2018, 00:51 -
What is the purpose of "Default" button in "Video" tab of XMedia Recode?
By MidnightUser in forum Newbie / General discussionsReplies: 1Last Post: 15th Jan 2016, 04:08
