So I end up with subtitles like:
"MoTHER: <i>welcome.</i>"
"<i>(THE ENTRY OF THE GODs
lNTO vALHALLA</i> PLAYING)"
"DAVID: (AS wALTER)"
Etc.
Is there anything I can do to fix it?
Uncheck auto-correct and fix them,it's a pain but that's the only way to get reliable results.
Well, yeah, that's the obvious answer but I don't really fancy manually editing tens of thousands of subtitles to be honest. There's nothing that can make the OCR work better? I'd expect the occasional mistake, sure, but it just refuses to count any of those letters as capitals, ever.
If your editing thousands of subtitles hire other people cause that's too many subs for anyone to work on.
A movie has one subtitle with thousands of words,not the other way around.
You may be able to speed things up by setting everything to lowercase, then sentence case in Word or equivalent.
Tesseract 3.02 gives far better results than the default binary image compare, although it tends not to catch spaces at times. Significantly fewer overall errors though.
Subtitle Edit Doesn't recognise my LAV Filters
By abrogard in forum SubtitleReplies: 1Last Post: 18th Sep 2019, 04:42 -
Downloading new OCR dictionary to Subtitle Edit 3.5.4
By flipside555 in forum SubtitleReplies: 2Last Post: 5th Jun 2019, 11:08 -
Subtitle Edit OCR import issue
By nunit in forum SubtitleReplies: 3Last Post: 16th Apr 2019, 19:48 -
Why does this happen after OCR with Subtitle Edit?
By rocknrolla115 in forum SubtitleReplies: 5Last Post: 24th May 2018, 07:30 -
subtitle edit ocr for French
By howtwosavealif3 in forum SubtitleReplies: 2Last Post: 29th Mar 2017, 12:03
