Try DVDFab and copy Ultra HD Blu-rays and DVDs! Or rip iTunes movies and music! Download free trial !
  1. Hello.
    I have a 5' X 7' green screen that I have had forever. I believe it might have come bundled with Pinnacle Studio software years ago. I have recently started using it to live stream but we need a larger green screen. The old on that I have is a tightly woven material and seems to be a polyester type fabric that is stretchy and it is a light lime green color. We have one shop light on the floor underneath the green screen and it lights it perfectly. I purchased one recently that is muslin fabric and is a much darker color. This makes it almost impossible to light evenly and adequately in our small space. I have searched high and low and I can't find the fabric or color like the older screen.
    Does anyone have any info on where I might can find the polyester, stretchy fabric in lime green?
    Thank you for your help and input,
    Dawn
    Oct 2018
    Gillette Stadium, United States
    Itís not the fabric so much as the color.
    Try Cowboy Studio. There are others. I got a pine green screen once from a no name vendor and it was useless.
  3. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    https://au.rosco.com/en/product/chroma-key-paint If it's practical to paint a wall
    BeyonWiz T3 PVR ~ Popcorn A-500 ~ Samsung ES8000 65" LED TV ~ Windows 7 64bit ~ Yamaha RX-A1070 ~ QnapTS851-4G
  4. Thank you all for the suggestions. I did find some lime green polyester poplin fabric online fir $4.00 per yard. I ordered it and I can whip stitch a rod pocket. Hopefully, it will work. If not, I will bite the bullet and purchase one of these suggestions.
    Thanks again,
    Dawn
