Below is a screenshot of same frame in video time (00:02:58.84) (HH:MM:SS.MS)
[Attachment 54218 - Click to enlarge]
Below is a screenshot of the same frame in video timecode (10:02:58:21) (HH:MM:SS:FF)
[Attachment 54219 - Click to enlarge]
I received a bulk amount of subtitles and the time start and time end of each subtitle is using timecode instead of time.
During playback, the player does not show the subtitles because it thinks that the start is in 10 (hours).
How to make player reference the timecode in a video instead of time?
You could use a subtitle program such as Subtile Edit and change all times earlier or later.
if the offset is a container feature (happens with transport streams) remuxing the file might already be enough,...
How do I get the timecode of the first frame using a command-line tool?
By Simon_Haddad in forum Video ConversionReplies: 0Last Post: 12th Jun 2020, 20:32 -
How to stop timecode showing on capture
By ozstar100 in forum Capturing and VCRReplies: 11Last Post: 30th May 2020, 13:28 -
Adobe Premiere Timecode Color Change
By Tarsha Schaller in forum EditingReplies: 0Last Post: 18th Mar 2019, 20:50 -
FFMPEG: how to extract audio from a specific timecode point?
By marcorocchini in forum Newbie / General discussionsReplies: 8Last Post: 2nd Jul 2017, 12:38 -
x264 10bit timecode error
By knightplex in forum Video ConversionReplies: 1Last Post: 9th Nov 2016, 13:57
