Hello everyone! I regularly use Kodi as my media player and have some streams I view from it. I have noticed that especially with 1080p links, I end up with green pixelation and artifacts. When I drop down to 720p this barely happens. I have adjusted the player's acceleration settings and such, but then playback gets choppy. I am curious if the streams weren't properly encoded, so they play back poorly, or is my media player (an android box using KODI) is the issue. Thanks in advance!
You're accessing these streams directly from your Android box streamed to the TV?
You could try accessing the same streams from the PC and check the quality there -
It is also possible that the problem is with streams being too big to handle for the players unless you increases cache (delay).
Try increasing the "Network Cache" in Kodi options (there's a how to in their wiki). The stream may get a few second delay,but that way you'll avoid all the glitches you're experiencing.
For example, if the 1080p stream has a bitrate of 10Mbit/s and the network cache set is only 3Mbit (VLC,etc Default) no wonder why you are getting glitches/green pixels/freezes/etc. -
So I noticed that on my laptop, the video playback is flawless. However on lesser quality streams, regular 1080p, not x264 or x265, the audio gets staticy. Sviests, I will look into your suggestion. With these higher quality links, there could be the issue you mentioned. Thanks for your suggestion!
video quality question
By samer1990 in forum Authoring (Blu-ray)Replies: 2Last Post: 7th May 2020, 22:15 -
Newbie question, convert my 23.976 movies to 25.000 without losing quality?
By box4m in forum EditingReplies: 10Last Post: 12th Jun 2019, 01:01 -
Panasonic DMR-EZ48V DVD/VCR VHS Combi - Transfer quality question
By vcogent in forum Newbie / General discussionsReplies: 3Last Post: 6th May 2017, 10:03 -
Any idea how to get the maximum quality videos from these MTV streams?
By deepblue-9 in forum Video Streaming DownloadingReplies: 2Last Post: 4th Aug 2016, 08:34 -
Converting to HEVC without loosing any streams and/or quality
By Hazuzi in forum Video ConversionReplies: 1Last Post: 24th Mar 2016, 16:46
