I've previously used VSDC for video editing, but I seem to keep getting bad output files with it, so I'm trying to learn how to use Shotcut. With VSDC I could manually change the resolution of the project I'm working on. Is there a way to do this in Shotcut as well? I have a video that is 608x1080 and I want to rotate it sideways and change the resolution to 1080x608. I've figured out the rotation part, but can't figure out a way to change the resolution of the project so that the video fills the screen top to bottom and doesn't get cropped on the sides.
Settings => video mode => custom => add ; then you can make a custom setting project (timeline) setting. Then you can apply rotation and scale filter
Alternatively , if you have a compatible container such as mp4, you can batch rotate them with metadata using ffmpeg (no quality loss, stream copy) . eg. portrait will display as landscape in most video players ; and shotcut also reads rotation metadata
Currently there is no way to disable autoscaling of imported assets in shotcut. But if you had a 1920x1080 timeline, that's 16:9 aspect ratio, just like 1080x608 is 16:9 (or very close to). So if imported a 608x1080 (with rotation metadata so it displays as 1080x608) onto a 1920x1080 timeline, it would automatically scale up and fill the 1920x1080 . Similarly , if you had a 640x360 project (also 16:9), it would scale down the video to fit
Using Shotcut features in Kdenlive
By DeJay in forum LinuxReplies: 2Last Post: 20th Jul 2019, 12:22 -
computer video editing help / Shotcut / windows 10
By Joe S in forum Newbie / General discussionsReplies: 1Last Post: 14th Feb 2019, 20:14 -
Blackberry 9720 not playing videos created with Shotcut. Why?
By oduodui in forum Portable VideoReplies: 2Last Post: 10th Jun 2016, 07:19 -
What video codecs should I use to encode to ogg with Shotcut?
By Bruce Wayne in forum Video ConversionReplies: 4Last Post: 23rd Apr 2016, 14:31 -
Premiere: How make a project at 704x576 resolution?
By Gameshow Host in forum EditingReplies: 22Last Post: 3rd Jan 2016, 13:11
