After searching and trying many examples in both Avisynth and ffmpeg, none of the methods I have tried will stack 3 videos with padding for a final result of 854x480.. for example I have 3 videos with widths of 252, 100, 252 respectively with the height all the same 360 and I would like to stack horizontally with (I assume) padding left and right after the height is adjusted to 480(480/360=1.333333AR , 252*1.333333=336 width video1, 1.333333*100=134 width video2, 252*1.333333=336 width video3.
I'm assuming that would leave all 3 stacked for a total width of 336+134+336=806. This would need padding pillar bars of 24 at each side. I don't mind if its avisynth stack or ffmpeg hstack but I cannot get any scripts to work.
Any help would be greatly appreciated.
Thank You
Should be rather simple in AviSynth... replace YourFavSource and YourFavResize with appropriate filters and provide the file names as strings.
If something fails, report the exact error messages. There are a few constraints, e.g. color spaces must match...Code:left = YourFavSource(leftfilename).YourFavResize(336,480) center = YourFavSource(centerfilename).YourFavResize(134,480) right = YourFavSource(rightfilename).YourFavResize(336,480) StackHorizontal(left,center,right) AddBorders(24,0,24,0)
Thank you LigH.de . Works like a charm. Never thought of using add borders but that is better since I can compute/alter those odd (not divisible by 2 for YUV) borders and video size as well.
Thank you again.
Will there be interference if you stack VCRs and entangled av cables?
By digicube in forum Capturing and VCRReplies: 20Last Post: 5th Jul 2017, 20:20 -
ATI 600, no padding at 352 capture, 15:11 the correct AR with 720 padding?
By jimj in forum Capturing and VCRReplies: 7Last Post: 23rd Jun 2016, 00:51 -
What to do with a stack of DVDs I need to view
By tpapictures in forum DVD RippingReplies: 20Last Post: 25th Jan 2016, 17:00 -
Trying to get video off stack of DVDs with identical directory error
By David Cooper in forum Newbie / General discussionsReplies: 2Last Post: 11th Dec 2015, 04:41 -
Why is padding used in videos/movies ?
By devvaibhav in forum Newbie / General discussionsReplies: 16Last Post: 12th Aug 2015, 19:12
