Results 1 to 30 of 43
    Aug 2008
    Greece
    Hi.
    Can you tell me some really light program that can convert dts or dts-hd to simple ac3 5.1 sound without loosing quality and fast?
    And still supported.
    Does these program do that:
    Mkvtoolnix
    Makemkv
    tsmuxer
    A lot of thanks for your time and your answers.
  2. Anonymous872
    Guest
    so I used the 'eac3to' tool a few times.
    for what I wanted it served me well, I just don't know if it's the best tool available.
    Last edited by Anonymous872; 19th Jul 2020 at 19:48. Reason: link is not necessary
    Aug 2008
    Greece
    No i don't like this program.
    To many parameters and real to many time simply to convert only the sound of a mkv file not the video.
    Is there any other program with no so many paramters?
    Simply you choose the mkv file with dts or dts-hd sound and convert it into mkv file with a simple ac3 5.1 surround.
    Mar 2008
    Avidemux. Use the portable 64 bit version.
    https://www.videohelp.com/download/avidemux_r200705_win64Qt5_25.zip
    Leave the video as "copy", set audio to ac3 (Aften) or ac3 (Lav).
    Use the configure and filters buttons for other adjustments
  5. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Popcorn Audio Converter changes DTS etc to AC3 in situ, leaves video alone and is quick.
  6. I'm a Super Moderator johns0's Avatar
    canada
    I use audacity with ffmpeg plugin to convert to dd 5.1 and then mux with mkvmerge,that way you can merge other stuff at the same such as subtitles.
    Aug 2008
    Greece
    There isn't any all in one program that with easy and quick way just convert dts or dts-hd into ac3 without do anything at all at video?
    Mar 2008
    reread the previous responses the info you want is there, with at least two suggestions that mention the video is left untouched or copy only
  9. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Not so
    I use Popcorn Audio converter almost weekly removing unnecessary audio tracks, subtitles converting DTS to AC3 etc etc. from MKV files. If I have a MP4 file that needs change I wrap in in a MKV container first using MKVToolNix then attack it as outlines!!! Doesn't touch the video at all.
    Aug 2008
    Greece
    Anyone has to suggest any program like tencoder?
    So light, so simple and do the work.
    Cause tencoder stop supporting anymore.
    Mar 2008
    Have you looked at Xmedia Recode ?
    Aug 2008
    Greece
    I check it now.
    Does it has any limitation the free version?
    Aug 2008
    Greece
    tencoder is really too much faster than xmedia recode.
    Really faster.
    Maybe cause tencoder transform only audio and copy video same time and xmedia 1st recode audio and then it add video so this is more than double of the time tencoder do.
    Mar 2008
    If your requirement is only to convert the audio and copy the video, continue to use Tencoder.
    Avidemux can do it, but I believe you lose any subtitles with that one
    Aug 2008
    Greece
    I don't care about subtitles.
    I can use external subtitles this is not problem at all.
    Is the avidemux as fast as it is tencoder?
    Avidemux it isn't convert audio or video files.
    Really i don't find anything like tencoder. Really fast and do the work.
    Mar 2008
    Easy enough to try, you'll find the portable 64 bit version on this site, software section
    Aug 2008
    Greece
    You don't understand i have already try the avidemux.
    At my previews post i tell you my opinion about that.
  18. Member Ennio's Avatar
    May 2005
    Netherlands
    ... to simple ac3 5.1 sound without loosing quality...
    FYI when you recode to AC-3 you will always have (small, maybe inaudible ) quality loss. AC-3 is a lossy encoder.
    Would that opninion be this?
    I don't understand what you mean by that.
    davexnet explained on how to use Avidemux to accomplish what you want.
    Can you be more specific about what problems you run into using Avidemux?
    Aug 2008
    Greece
    Now the tsmuxer SUPPORT the convert from true-hd to ac3.
    But unfortunately at some true-hd doesn't convert it successfully.
    I mean exactly that i am saying for avidemux IT ISN'T convert anything it simply demuxing as it say and his name.
  20. Member Ennio's Avatar
    May 2005
    Netherlands
    I doubt that tsMuxer is doing converting/recoding of audio.
    I think tsMuxer is able to separate the embedded AC-3 track from the TrueHD track. According to bluray specs it's mandatory that TrueHD tracks have an embedded, independent AC-3 track for legacy purposes.
    ...avidemux IT ISN'T convert anything...
    If you do this Avidemux will recode audio to legacy AC-3
    Aug 2008
    Greece
    The new and updated version of tsmuxer IT CAN.
    Just read the changelog.
  22. Member Ennio's Avatar
    May 2005
    Netherlands
    Just did. But I can't find anything about (re-)coding audio.
    Can you point me out please?
  23. Member
    Aug 2008
    Greece
    I NEVER SAY recoding.
    I just say converting - downsampling NEVER RECODING.
  24. Member Ennio's Avatar
    May 2005
    Netherlands
    AFAIK downsampling takes place in the uncompressed audio realm. Calculating less (or more, with up-sampling, for that matter) new samples is by definition not lossless. Even if you wouldn't change bitdepth.
    Those new samples will have to be compressed again (recoded) into your wanted AC-3, which is also not lossless.
    I still doubt that tsMuxer does that. I didn't read anything about converting or downsampling in the changelog. Please point me out if it's there.
    BTW next to extracting the embedded AC-3 track in TrueHD audio, tsMuxer can also get the dts core out of DTS-HD audio.
  25. Member
    Aug 2008
    Greece
    What is afaik?
    And why you don't try to downconvert one truehd into ac3 with latest tsmuxer to check it?
    How tsmuxer can convert dts to dts-hd?
  26. Member Ennio's Avatar
    May 2005
    Netherlands
    What is afaik?
    Sorry, it means "as far as I know".
    It isn't downconverting. It just demuxes the embedded AC-3 audio that is already there in a TrueHD track. You said:
    ...unfortunately at some true-hd doesn't convert it successfully.
    That "some" TrueHD tracks won't work with tsMuxer, is because there is no embedded track to demux. Again, it has nothing to do with "converting". I'll explain.
    If you import bluray into tsMuxer, a TrueHD track always will have an embedded AC-3 audiotrack. It's mandatory for BD specs.
    In such a case, the trackinfo screen will say "AC3 core + TRUE-HD". This "core" is misleading; it's not a core (see further at the dts part of this post). It's the embedded (and independent) AC3 track. So it's like 2 tracks in one. It is this embedded track that tsMuxer can demux/use for you by ticking the "Downconvert TRUE-HD to AC3"-box.
    Now, try to import a mkv which has TrueHD into tsMuxer. It will throw a window at you saying that "track ** wasn't recognized". This is because within a mkv container it's not possible to have an embedded AC-3 track within TrueHD audio as one track and tsMuxer sort of "expects" TrueHD with embedded AC-3. It kinda refuses "TrueHD only", so to say.
    Mind that you can of course simply mux an extra AC3 track into mkv as an additional audiotrack.
    Again, it's not really converting anything.
    DTS-HD audio is different in build-up than TrueHD. First, it has a "dts core". This is a dts track like you find on dvd's. Most of the times it's in 5.1. But there are several channel numbers/configurations, all up to 6.1. Next to this core, there is extra data. The core, together with the extra data makes up for the total DTS-HD audio.
    In tsMuxer, when you tick the "Downconvert DTS-HD to DTS"-box, it will only demux and use the dts core. So, again nothing is really "converted"; the core is already there.
    To be complete, mkv's can carry the DTS-HD audio (with it's core) in one audiotrack.
  27. @fits79
    The title of the post started with DTS to AC3 .. uhmm ..
    you have not thought to use UsEac3to ... the last update is much better ...
    責任者-MDX
  28. Member
    Aug 2008
    Greece
    Please READ THE FULL TITLE of the topic not only part of.
    And 2 files i try it doesn't convert e-ac3 to ac3.
  29. Originally Posted by sekininsha View Post
    Hi,
    I'm trying to do the following.
    Take an .mkv (4K UHD made with makemkv)
    Keep the video track as is
    Keep all audio tracks as is
    Add an additional audio track taking the DTS track and convert it to AC-3
    Keep all subtitle tracks as is
    When I use UsEac3to with these settings
    I end up with a bunch of different files instead of a .mkv.
    Am I missing something?
