Greetings Everyone. one quick question, is there any way to remove the water mark from clonebd? if this isn't the proper place for this question i apologize in advance.
Thanks alot
Fr@nkC@$tle
Yes. Hundreds of posts about doing this: https://www.videohelp.com/search?q=remove+watermark
However, the end result is always the same. Even with the best possible result, there's always a loss of quality because you have to reencode and save the edited video.
You've already been given the best answer in one of your other threads. Stop using CloneBD, which few here use or recommend and use DVDFab which is highly used and recommended here, and won't place a watermark on your RIP.
If you don't have original commercial disc to properly RIP, the conversation stops here as you're no longer covered by Fair Use.
Removing dirt and pock marks
By ZetaStax in forum Video ConversionReplies: 5Last Post: 11th Oct 2019, 09:00 -
DVD with hidden chapter marks? (subchapters)
By TechLord in forum Authoring (DVD)Replies: 3Last Post: 30th Sep 2017, 17:22 -
Removing water damage from film
By bmick23 in forum RestorationReplies: 13Last Post: 18th Jun 2017, 18:17 -
do you use liquid/water cooler ?
By rama in forum ComputerReplies: 25Last Post: 18th Apr 2016, 06:38 -
Trapcode Particular water help
By SamBaker4 in forum EditingReplies: 2Last Post: 16th Feb 2016, 10:05
