I'm trying to QTGMC a DVD I have. I'm getting blended frames. I was hoping to keep the frame rate bobbed at 50fps but I'm not sure what the original frame rate was. I've read this can be fixed with srestore but I'm at a loss. Any direction would be greatly appreciated. I'm not sure where to start. I've provided a clip below.
I'm using Avisynth with AvsPmod.
https://www.dropbox.com/s/gy77jxy8hx3bhpk/sw.mkv?dl=0
Thanks for your suggestion. It works for most parts but some frames here are there aren't fixed and i get a gray frame randomly every 10-20 frames. Do you have any other suggestions? Also, what does the "1.001" do in the script you provided? Is it to get all the decimal places in 23.976? Thanks for your help!
NTSC blended from a PAL source, wobbly after srestore
By bruno321 in forum RestorationReplies: 16Last Post: 28th Oct 2018, 12:29 -
How to remove blended frames from NTSC 29.976?
By midts in forum Video ConversionReplies: 2Last Post: 15th Aug 2018, 12:07 -
field blended anime (PAL)
By x264 in forum Newbie / General discussionsReplies: 5Last Post: 13th Jun 2018, 06:11 -
PAL to NTSC with avisynth - blended frames
By nesburf in forum Video ConversionReplies: 7Last Post: 27th Dec 2017, 23:21 -
Removing Blended frames, then putting unblended duplicates back in??
By killerteengohan in forum RestorationReplies: 17Last Post: 16th Oct 2015, 03:37
