Hi,
I previously had Acer S680G, the motherboard/GPU failed, everything else is ok.
i5-750 2.66GHz
4GB DDR3. 640GB.
Fx 380 512 mb – Graphics card.
Premiere CC 2018 worked ok, a little slugish but done the job.
Note: Moved prevous HD with OS to other computers, long as Computer accepts the same storage type!
I can work around issues.
Have lost job and have very limited money due to Corona virus.
Need to choose a replacement refurbished PC box with limitation.
I am looking at spending around $150 for PC box, and could do with any direction you can offer.
Understand the performance will not be good, just working with what I have:
Old HD loaded with win7 and Premiere CC 2018
2x 2GB Memory sticks from Acer S680G (If the new computer has at least 4GB memory and accepting slots the total would then be 8GB).
I would like advice on PC CPU/Graphics card combination.
Regarding Acer Veriton X4630G with Intel HD Graphics 4600.
The maximum shared Vram Memory is about 2GB, but said to be of lesser value then onboard versions?
How can I compare Vram to an onboard Memory, Graphics Cards.
Am I better off with GeForce 9500 GT, 512MB of memory on board or another option?
Can spend around $150 on PC box, choices here: https://www.reboot-it.com.au/used-computers/
Looking at Acer Veriton X4630G with Intel HD Graphics 4600. (No idea about choosing the right product)
I could buy another version of box, and add ATI FirePro V4900 1GB DDR5 128-bit DVI separatly for $35.
Since been told that Premiere would not use FirePro V4900, so it would run on software.
There other PC Graphics versions if you can point out any options:
Some PC combinations are outside budget of around $150.
Firepro V3750
FirePro V4900
GeForce 210
Geforce 7600 Gs
Geforce 8800 Gt
GeForce 9300
Geforce 9400 Gt
Geforce 9500 Gt
Geforce G210
Geforce Gtx 260
Geforce Gtx 275
Geforce Gtx 460
HD GRAPHICS
Integrated/On-Board Graphics
Intel 4 Series Graphics
Intel HD 530 Graphics
INTEL HD 6000 GRAPHICS
Nvs 300
Quadro 2000
Quadro Fx 1500
Quadro K2000
Quadro Nvs 295
Quadro Nvs 420
Radeon HD 8490 / R5 235X Oem
Radeon R5 340
Radeon Xpress 200 Series
I wouldn't buy anything if I were you. If you lost your job and all you can swing is $150, I suggest you put that money on the side in a "new PC fund" and wait until this is over and you are working again.
Not an option, purchased Acer Veriton X4630G with Intel HD Graphics 4600
GPU or CPU encoding?
By m00511 in forum Newbie / General discussionsReplies: 44Last Post: 17th Nov 2019, 20:03 -
Premiere 2018 GPU
By markus in forum EditingReplies: 6Last Post: 25th Sep 2019, 15:11 -
choosing software and cpu
By djordjejovanovic in forum EditingReplies: 6Last Post: 18th May 2018, 21:46 -
HEVC or H264 GPU vs CPU Another time !!!
By gringito38 in forum Video ConversionReplies: 2Last Post: 23rd Feb 2018, 06:28 -
There is too much about GPU vs CPU encoding, but how about GPU filters?
By Bernix in forum Newbie / General discussionsReplies: 24Last Post: 16th Feb 2018, 17:17
