Hello all,
I have a Samsung Smart TV and Sony home theatre system both of them only support up to DD+. But I have a collection of HD movies (Bluray ripped) which only has DTS audio tracks in them. So, I'm planning to demux the DTS track using an application like tsmuxer then convert that track into E-AC-3 and finally mux them all back together. So, I can play movies using dlna and still keep DTS. I have the following questions if you can advice please?
1) What is the best software (preferable freeware) that can convert DTS to E-AC-3 without loss of surround quality?
2) Reason I'm sticking to E-AC-3 is it is more latest format but what bitrate would you recommend say if source DTS track is 1500kb/s?
Thanks in advance.
Results 1 to 10 of 10
Popcorn MKVAudioconverter and do it. The item you want is listed under the File menu and not the tabs as Simple Audio conversion. It will do it in situ in one go.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
"Programmers are human-shaped machines that transform alcohol into bugs."
640 kbps at 5.1 channels from 5.1 dts.
Are there any pros in keeping a DTS audio track if a DTS-HD is available?
By alexd15 in forum Authoring (Blu-ray)Replies: 3Last Post: 13th Feb 2019, 06:22 -
Is it possible to remove audio files from an mkv without de-/re-muxing?
By pinkfloydfan in forum Newbie / General discussionsReplies: 10Last Post: 18th Nov 2018, 13:29 -
modified muxing.c - how to preserve audio quality
By oifii in forum Newbie / General discussionsReplies: 0Last Post: 16th Jan 2016, 07:38 -
Physical Media Player that supports H.265, 10bit and lossless Dolby/DTS?
By VideoFanatic in forum Blu-ray RippingReplies: 0Last Post: 30th Oct 2015, 14:34 -
Muxing MP4 (Audio+Video) to M4A (Audio)
By meganoob in forum AudioReplies: 4Last Post: 4th Oct 2015, 22:34
