Results 1 to 10 of 10
  1. Member jraju's Avatar
    Mar 2013
    India
    Hi, ofcourse, it is a downloaded video.
    i give below the audio details where i am having the problem.
    the video is mp4 and there is no problem in the video, so i only give the audio codec details from media info
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Format settings : Joint stereo / MS Stereo
    Codec ID : mp4a-6B
    Duration : 1 h 25 min
    Duration_LastFrame : -11 ms
    Bit rate mode : Constant
    Bit rate : 128 kb/s
    Channel(s) : 2 channels
    Sampling rate : 44.1 kHz
    Compression mode : Lossy
    Stream size : 78.0 MiB (6%)
    Writing library : LAME3.99.5
    Language : English
    Default : Yes
    Alternate group : 1
    It is converted mp3 audio file and the problem is that the audio is too low .
    the above details gives the audio detailed information.
    i tried with various players and the audio is feeble
    it is only for this file.
    Do the details show anything that concerns with low audio or is the problem with some other thing .
    ihe audio is audiable, but it gives the sound as if from a deep well.
    i played other audios and it is fine.
  2. Of course there's nothing in that information that would indicate the audio is at too low a level. Make sure you aren't down mixing to mono.
  3. Load your mp4 into my clever FFmpeg-GUI, click on Main, click on (Modify) Audio Stream, click on continue, set mp3 as output, check DynAudNorm, click on convert.
    Then click on Multiplex, set the new created Audio.mp3 as audio source, set the target file name, set audio language, set mp4 container, click on Multiplex, Done.
    (Read the HowTo.txt first).
  4. Member jraju's Avatar
    Mar 2013
    India
    Hi, prowo,
    i get error which i enclosed.
    i read the how to txt
    i just copied the ffmpeg, ffplay and ffprobe in to the same directory as the clever ffmpeg.
    what i am doing wrong.
    i do not get main menu, and when i open the exe, it just go to the source load page.
    there is no menu.
    expecting your reply
    please also give the lilnk, where the latest ffmpeg, ffprobe, and ffplay could be downloaded.
    there are so much confusion regarding the download
  5. Member jraju's Avatar
    Mar 2013
    India
    hi, prowo, i somehow managed to run your software.
    i did the same as per your instructions .
    when i select the menu, dy..., it suddenly started progressing bar and i wait and after done, i select as you say, the source video file already in the box,
    i selected the new audio file aac created by the software, i have choosen the mp3, and multiplex it and save the targeted file. the process went smooth.
    but , when i play the audio was still low.
    what would have been the issue, if there is no error is popping out.
    audio is too low to hear only for theis video.
  6. Member jraju's Avatar
    Mar 2013
    India
    Hi, prowo, Thank you for your solution.
    First let me know, why this low voice problem could you guage the reason
    now the sound is correctlyl play
    Buat getting to the solultion somewhat puzzles me.
    i went to the same folder as source, and found, that it has created one aac file and one mp3 file also.
    i had not noticed this, as the new creation cursor shows the aac file
    But i found the same folder has also has a mp3 file.
    Now i run your software, this time, straight to multiplexing menu
    just selected the audio mp3 file and then click multiplex.
    and the resultant mp4 file has correct audio.
    But the how to txt contains too limited txt to proceed and that is the reason that it is not known to many.
    You have to give it more to easily to educate the beginners.
    my sub query to you
    why subtitle is also there in your multiplex settings.
    what would it do the subtitles , please say.
    if suppose, you select a subtitle file what could be done with your software
    Thanks once again.
    please correct the read txt file as simple menu wise
  7. i went to the same folder as source, and found, that it has created one aac file and one mp3 file also.
    On the first attempt you have created a AAC audio (default setting).
    Fine...
    If your source video contains subtitles, you can mux them also.
  8. Member jraju's Avatar
    Mar 2013
    India
    Hi,thanks.
    hpw subtitles could be muxed
    please say.I had not heard.please explain.
    why my audio was low before I use yourg software
  9. Originally Posted by jraju View Post
    Why do you ask stupid questions like this? When you download crap from the internet you get what you get. Nobody knows why the person who made the video did what they did.
  10. Member jraju's Avatar
    Mar 2013
    India
    Hi, this is the only video that caused the issue. Ok skip it .my issue resolved by prowo. I will be vareful in my content jagobo
