I have a Magnavox MWD2205 DVD/VCR Combo in mostly good condition. DVD plays fine but every VHS tape I play has a hissing noise. Tried cleaning the heads lightly with alcohol but hiss remains. Any ideas where to look? Thanks
Assuming you're telling the OP to get a VHS HI-FI VCR as his combo and AFAIK all combo units are non-VHS HI-FI
OP, the fact is VHS linear audio is very, very poor and full of hiss and wow and flutter. In addition, you unit is mono only. You don't specify whether you cleaned the video or audio heads, but the audio head may be dirty or out of alignment. There's also the possibility that it's needs demagnetizing, but that's something I wouldn't recommend to anyone that doesn't fully understand the insides of the VCR.
Bottom line, the only way to get better audio is get a better VCR, ideally one with VHS Hi-FI if you tapes are recorded with it. -
lingyi,
I am looking at it for a friend. video head and audio heads have both been cleaned. I'll take a look at demagnetizing -
Is there a Dolby NR option. Dolby encoded tapes had a lot of high end noise when played without a Dolby decoder.
(Do not confuse Dolby Noise Reduction with Dolby AC3 encoding on DVDs)
VHS Noise
By Micheal81 in forum Capturing and VCRReplies: 15Last Post: 8th Feb 2020, 17:23 -
VHS S-video noise identification
By Tudor94 in forum Newbie / General discussionsReplies: 11Last Post: 26th Jan 2020, 21:45 -
Is it possible to remove this VHS noise using audacity?
By digicube in forum AudioReplies: 29Last Post: 14th Oct 2018, 18:13 -
VHS video noise
By Maris 55 in forum Capturing and VCRReplies: 31Last Post: 21st Jul 2018, 09:48 -
DVD Recorder with VHS? Magnavox? Toshiba?
By quxote in forum DVD & Blu-ray RecordersReplies: 31Last Post: 2nd Dec 2015, 18:47
