  1. Hi,
    I have a problem with Any Video Convertor. I have installed it and select the video file. I choose to convert it to a Customized MP4 movie from an MPEG.
    I hit "Convert Now!"
    It then instantly shows "Completed" under the video thumbnail and pops up a File explorer with a mp4 files that is 0 bytes. Does anyone know what the issue may be?
    I suspected permissions at first but that doesn't appear to be an issue after inspecting them.
    Thanks for your time.
    Oct 2005
    666th portal
    i don't think any people here use any video convertor. try a real free converter like vidcoder/handbrake.
  3. Originally Posted by videokilledtheradiostar View Post
    Hi,
    Have the same issue. Started to happen after the last update. However, if I choose another file type, it seems to work albeit with poorer quality than before. Anyway, I will probably go to Handbrake for now.
