Having a hard time identifying this car from the pictures. Can anyone help shade light on what the make is? These are screenshots from a security video clip, and I took the snapshots while 1) The car took off driving [tail only] 2) the car was at a stop (tail and break light), and 3) the car shifting from parked to drive while breaking (all lights)
1) When only the Tail light is ON
2) When the Break light and Tail lights are ON
3) When the Reverse, Break and Tail lights are ON
	If the image were truly stationary (aka both cam & car/subject are static), you MIGHT be able to do an HDR-based composite using average or median or stitching/stacking or differencing, etc. Then you MIGHT be able to tonemap the image so there is sufficient local contrast in the area of the license plate. And IF you had enough resolution/pixel density in the area of the license plate, you MIGHT be able convolve the area with a variety of smoothing/nr and sharpening methods, and maybe even edge detection, to be able to utilize OCR or maybe even have it visually recognizable.
 But I sincerely doubt it.
 GIGO
 ScottLast edited by Cornucopia; 12th Jul 2020 at 21:30.
	Thanks Cornucopia, its actually a screenshot from a security video recording. Its one of those Blink brand cameras which I believe has a not-that-good night vision, so I also doubt processing the screenshots your way would provide any usable clue, so I guess I should be looking for someone to just look at the shape of the car characteristics and try to identify the make/model/year kind of details.
  mpv how to identify files?By Selur in forum Newbie / General discussionsReplies: 8Last Post: 14th Mar 2020, 12:32
  Identify the car number from a videoBy Sissy in forum RestorationReplies: 0Last Post: 10th Mar 2019, 04:46
  Identify for MACBy carlosian in forum MacReplies: 2Last Post: 16th May 2017, 05:20
  unable to identify driver for capture cardBy codemaster in forum ComputerReplies: 2Last Post: 14th Mar 2017, 11:34
  Need help to identify the plate number of a carBy Viki in forum Newbie / General discussionsReplies: 15Last Post: 16th Dec 2015, 12:05
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
