MY old WD USB media player finally gave up the ghost and I need to find a replacement. I guess WD stop making these things. Anyone got a list of alternatives.
Read this thread about Android Box. It's the closest thing to a WD player, but there's nothing comparable to the great, IMHO, WD file interface. In addition, the WD boxes don't support H.264, H.265 and other newer formats, which unless you're only using your own homemade content or DVD or Blu-Ray rips, you'll encounter.
Basically your options are:
~$50-100 - Android Box or Raspberry Pi
~100-200 - Cheap laptop or refurb PC. My preference.
~200+- Nvidia Shield which is at it's core a custom Android Box
Roku is not on the list because of its focus on streaming and very limited options for non-streaming playback options.
I went through numerous WD boxes, starting with the original WD box and ending with the WD Live Streaming Plus and while I loved them, I don't regret using a laptop and cheap PC for the my two viewing setups. I tried Roku and Android, but they're limited compared to a PC which will just play almost any video format in any video container. -
I have used the Kodi app on the Nvidia Shield as my WDTV replacement, and have absolutely loved it. Among other reasons, I love it because by customizing the home screen you can eliminate the advertising crap you are exposed to. One of the strengths of the WDTV box was the lack of advertising intrusiveness.
And it has a better wife tolerance factor than a refurbished PC, in my experience.
Timeshift -Pause and Rewind on live TV, which player to do this ?
By marximus in forum Newbie / General discussionsReplies: 0Last Post: 21st May 2019, 03:52 -
Need help with downloading live streams from new player on camsite
By BiankaHolms in forum Video Streaming DownloadingReplies: 0Last Post: 19th Jul 2018, 10:14 -
Avidemux alternative
By Georgios in forum EditingReplies: 4Last Post: 13th Dec 2017, 01:09 -
Recommendations for media player - similar to WDTV Live
By Khalel in forum Media Center PC / MediaCentersReplies: 12Last Post: 9th Nov 2017, 12:21 -
Avermedia live gamer portable alternative with support for composite vide?
By david151 in forum Capturing and VCRReplies: 2Last Post: 16th Oct 2016, 22:24
