    Aug 2005
    Europe
    I have been advised that white thermal compound is silicone only and that I should use silver based instead for better results. How accurate is this?
    Oct 2005
    666th portal
    google thermal paste reviews. lots of good ones out there. i use a diamond based one.
  3. Anonymous
    Guest
    For what i know about it doesn't really matter that much, it may shave a few degrees of
    it is more important that there is a compound between de cpu and cooler rather than what. And don't use to much, a very thin layer is enough
    Aug 2006
    The shiny silver stuff is supposed to be more liquid than most other thermal compounds. The articles that I read warned that it isn't the ideal product for non-expert users because any excess that drips or flows where doesn't belong is difficult to completely remove.
    For my most recent build, I bought Thermal Grizzly Kryonaut Thermal Paste, 5.55g in part because it was supposed to be easier to apply than some other products. As a first-time thermal paste user, I was pleased with the product and the relative ease of application.
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    yes a problem with silver/metal pastes is that if you apply too much and it squeezes out onto the motherboard it is conductive and can short/fry the entire motherboard.
  6. I've been an Arctic Silver fan for years. Good price and good performance. There are better thermal compounds, but I'm not chasing perfection.
    Aug 2005
    Europe
    Which thermal compound from Arctic Silver are you using?
