Results 1 to 9 of 9
    Jul 2020
    Melbourne Australia
    Hi guys,
    I've spend an hour trying to fiddle with the source page of this https://radio.eol.co.il/live/ radio station to get the stream url so I can add it to my phone's podcast/radio station list.
    I've downlaoded the m3u8 playlist i could find on the source page but no url there. any ideas?
    any help much appreciated.
    thanks
    Roy
  2. Put the m3u8 url from the web page in a playlist: (m3u or m3u8 file):
    https://eol-live.cdnwiz.com/eol/eolsite/chunks.m3u8
    That works with VLC on my Android phone.
  3. similar problem here https://www.881903.com/live/903. I got the chunk.m3u8 but it is not playing anything.
  4. Originally Posted by RedRoo View Post
    Hi guys,
    thanks
    Roy
    use the playlist.m3u8 + nm3u8dl https://github.com/nilaoda/N_m3u8DL-CLI/releases/tag/2.9.9
    16:07:13.380 Start Parsing  https://eol-live.cdnwiz.com/eol/eolsite/playlist.m3u8
    16:07:14.638 Writing Json: [meta.json]
    16:07:14.723 Master List Found
    16:07:14.760 Writing Master List Json: [playLists.json]
    16:07:14.761 Auto Selected Best Definition
    16:07:14.762 Start Re-Parsing...
    16:07:15.165 Writing Json: [meta.json]
    16:07:15.197 File Duration: 00m35s
    16:07:15.199 Original Count: 6, Selected Count: 6
    16:07:15.199 Live Stream Found, Recoding...
    16:07:15.212 <18964 Downloading>
    16:07:15.419 <18964 Complete>
    it will continue recording till you close
    extension to get the m3u8 fast https://addons.mozilla.org/en-US/firefox/addon/hls-stream-detector/
  5. Originally Posted by mrplummy View Post
    same for you
    16:10:34.095 Start Parsing  https://live.881903.com/edge-aac/903hd/playlist.m3u8?r=XFBi3o8UAeZY9VfB
    16:10:39.953 File Duration: 00m36s
    16:10:39.955 Original Count: 6, Selected Count: 6
    16:10:39.966 Live Stream Found, Recoding...
    16:10:40.190 <18979 Downloading>
    16:10:40.623 <18980 Downloading>
    16:10:40.842 <18981 Downloading>
    16:10:41.138 <18982 Downloading>
    16:10:41.459 <18983 Downloading>
    16:10:41.840 <18984 Downloading>
    16:10:42.066 Waiting...
  6. Originally Posted by jagabo View Post
    If that URL doesn't work try removing the "s" from "https://":
    http://eol-live.cdnwiz.com/eol/eolsite/chunks.m3u8
  7. Originally Posted by PUOPUO View Post
    same for you
    I got the master.m3u8 using the software, but vlc said fail to start playback. I opened the file and it basically includes a ton of chunks.m3u8 paths.
  8. Originally Posted by mrplummy View Post
    same for you
    it will have direct playback errors, dunno why, if you want to download instead use what i mentioned, nm3u8dl
  9. Originally Posted by mrplummy View Post
    ffplay can play the m3u8 with
    ffplay -user_agent "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0" -headers "Cookie: CloudFront-Policy=eyJTdGF0ZW1lbnQiOlt7IlJlc291cmNlIjoiaHR0cHM6Ly9saXZlLjg4MTkwMy5jb20vZWRnZS0qLyoiLCJDb25kaXRpb24iOnsiSXBBZGRyZXNzIjp7IkFXUzpTb3VyY2VJcCI6IjcyLjIyMC4xODEuOTQvMjQifSwiRGF0ZUxlc3NUaGFuIjp7IkFXUzpFcG9jaFRpbWUiOjE2NTA5NzA5MjJ9fX1dfQ__; CloudFront-Signature=QbgzqqlSquMgn6FK6IoU9aktVLTX4S8QqOUT%7EtOtdvJ8qgTyiJtfD2xM6GlRtQmQ03MPK5O1HzUsk2sPbpZVRS7p6SXssaDRHhRgA9yp4rYt1GFA4UMHHzn15HdJglitlbg8mBc2S4rnER%7EqulWU%7EJK6FhzKLMJKZWy5mm-ugaxxcKWrvggJOfcXQkwoI6Ta1XEFFIXHU5lqcL03nqj7q-k-q-oJm0ceP6WzVY%7EczV0rtayND7YiSAYv8k9cjlnSVy6drGoH7yjtjqZ1AZ6vcHpECr5xYi983USsDIMqpha0Q2iRucatbYryLNeY7N29vOTNfg57THts834mzC5Scg__; CloudFront-Key-Pair-Id=APKAJD57M4WB2ORCAM4Q" -referer "https://www.881903.com/live/903" -i "https://live.881903.com/edge-aac/903hd/playlist.m3u8?r=RpjoZvJJbt8ymYGe"
    Oddly, it works from the command line but not in a batch file. I got the command line from The Stream Detector plugin for Firefox in Windows 10.
    <edit>
    I figured out why it doesn't work from a batch file: each of the "%7E" needs to be changed to "%%7E":
    ffplay -user_agent "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0" -headers "Cookie: CloudFront-Policy=eyJTdGF0ZW1lbnQiOlt7IlJlc291cmNlIjoiaHR0cHM6Ly9saXZlLjg4MTkwMy5jb20vZWRnZS0qLyoiLCJDb25kaXRpb24iOnsiSXBBZGRyZXNzIjp7IkFXUzpTb3VyY2VJcCI6IjcyLjIyMC4xODEuOTQvMjQifSwiRGF0ZUxlc3NUaGFuIjp7IkFXUzpFcG9jaFRpbWUiOjE2NTA5NzA5MjJ9fX1dfQ__; CloudFront-Signature=QbgzqqlSquMgn6FK6IoU9aktVLTX4S8QqOUT%%7EtOtdvJ8qgTyiJtfD2xM6GlRtQmQ03MPK5O1HzUsk2sPbpZVRS7p6SXssaDRHhRgA9yp4rYt1GFA4UMHHzn15HdJglitlbg8mBc2S4rnER%%7EqulWU%%7EJK6FhzKLMJKZWy5mm-ugaxxcKWrvggJOfcXQkwoI6Ta1XEFFIXHU5lqcL03nqj7q-k-q-oJm0ceP6WzVY%%7EczV0rtayND7YiSAYv8k9cjlnSVy6drGoH7yjtjqZ1AZ6vcHpECr5xYi983USsDIMqpha0Q2iRucatbYryLNeY7N29vOTNfg57THts834mzC5Scg__; CloudFront-Key-Pair-Id=APKAJD57M4WB2ORCAM4Q" -referer "https://www.881903.com/live/903" -i "https://live.881903.com/edge-aac/903hd/playlist.m3u8?r=RpjoZvJJbt8ymYGe"
    % is a special character in batch files. To pass a % to the program you need %% in the batch file.
    The cookie will vary depending on your IP address (if I use a VPN I get a different cookie), I believe. So you'll need to get your own.
    </edit>
