Briefing
I have some .wmv files (actually, my full batch file deals with multiple filetypes) with weird data streams that are needed for an external program to recognize them.
I'm trying to remove every stream that is not data or audio, which also needs to be reencoded.
The minimal command I'm using for what I'm discussing is
Which works for other file types with the same type of data stream and will work with .wmv if I add "-dn" (even though my file is then not recognizable by the external program). The command above, as is, for .wmv files will output the error "Could not write header for output file #0 (incorrect codec parameters ?): Operation not permitted".Code:fmpeg -y -loglevel debug -flags global_header -err_detect ignore_err -fflags +igndts -copy_unknown -i "input.wmv" -f asf -c copy -map 0 -vn -sn -b:a 32k "output.wmv"
From FFprobe (full output below), I can see the message "Unsupported codec with id 0 for input stream 2", so I believe it's beyond doubt that the cause is indeed the data stream.
Question
The thing is that I expected "-copy_unknown" to deal with this and it doesn't. My question is: how do I copy this unsupported, not used anywhere else data stream? Are there other ways to approach the matter?
Extra info
Full FFmpeg output (with "-loglevel debug"):
FFprobe on a sample file:Code:ffmpeg version 4.2 Copyright (c) 2000-2019 the FFmpeg developers built with gcc 9.1.1 (GCC) 20190807 configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-amf --enable-ffnvcodec --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt libavutil 56. 31.100 / 56. 31.100 libavcodec 58. 54.100 / 58. 54.100 libavformat 58. 29.100 / 58. 29.100 libavdevice 58. 8.100 / 58. 8.100 libavfilter 7. 57.100 / 7. 57.100 libswscale 5. 5.100 / 5. 5.100 libswresample 3. 5.100 / 3. 5.100 libpostproc 55. 5.100 / 55. 5.100 Splitting the commandline. Reading option '-y' ... matched as option 'y' (overwrite output files) with argument '1'. Reading option '-loglevel' ... matched as option 'loglevel' (set logging level) with argument 'debug'. Reading option '-flags' ... matched as AVOption 'flags' with argument 'global_header'. Reading option '-err_detect' ...Routing option err_detect to both codec and muxer layer matched as AVOption 'err_detect' with argument 'ignore_err'. Reading option '-fflags' ... matched as AVOption 'fflags' with argument '+igndts'. Reading option '-copy_unknown' ... matched as option 'copy_unknown' (Copy unknown stream types) with argument '1'. Reading option '-i' ... matched as input url with argument 'C:\Users\Fabio\Desktop\Testes\test\a.wmv'. Reading option '-f' ... matched as option 'f' (force format) with argument 'asf'. Reading option '-c' ... matched as option 'c' (codec name) with argument 'copy'. Reading option '-map' ... matched as option 'map' (set input stream mapping) with argument '0'. Reading option '-vn' ... matched as option 'vn' (disable video) with argument '1'. Reading option '-sn' ... matched as option 'sn' (disable subtitle) with argument '1'. Reading option '-b:a' ... matched as option 'b' (video bitrate (please use -b:v)) with argument '32k'. Reading option '\Users\Fabio\Desktop\Testes\test\a.wmv.tmpoutput' ... matched as output url. Finished splitting the commandline. Parsing a group of options: global . Applying option y (overwrite output files) with argument 1. Applying option loglevel (set logging level) with argument debug. Applying option copy_unknown (Copy unknown stream types) with argument 1. Successfully parsed a group of options. Parsing a group of options: input url C:\Users\Fabio\Desktop\Testes\test\a.wmv. Successfully parsed a group of options. Opening an input file: C:\Users\Fabio\Desktop\Testes\test\a.wmv. [NULL @ 0000025955e7af40] Opening 'C:\Users\Fabio\Desktop\Testes\test\a.wmv' for reading [file @ 0000025955e7b740] Setting default whitelist 'file,crypto' [asf @ 0000025955e7af40] Format asf probed with size=2048 and score=100 [asf @ 0000025955e7af40] gpos mismatch our pos=24, end=244 [asf @ 0000025955e7af40] gpos mismatch our pos=24, end=26 [asf @ 0000025955e7af40] gpos mismatch our pos=24, end=3295 [asf @ 0000025955e7af40] Payload extension 50 2 [asf @ 0000025955e7af40] gpos mismatch our pos=24, end=42 [asf @ 0000025955e7af40] gpos mismatch our pos=24, end=44 [asf @ 0000025955e7af40] gpos mismatch our pos=24, end=834 [asf @ 0000025955e7af40] Before avformat_find_stream_info() pos: 5793 bytes read:32768 seeks:0 nb_streams:3 [asf @ 0000025955e7af40] parser not found for codec wmav2, packets or times may be invalid. [wmv3 @ 0000025955eb4480] Header: 46690A01 [wmv3 @ 0000025955eb4480] Profile 1: frmrtq_postproc=3, bitrtq_postproc=6 LoopFilter=1, MultiRes=0, FastUVMC=0, Extended MV=0 Rangered=0, VSTransform=1, Overlap=1, SyncMarker=0 DQuant=0, Quantizer mode=0, Max B-frames=0 [wmv3 @ 0000025955eb4480] Extra data: 8 bits left, value: 0 [wmv3 @ 0000025955eb4480] Format yuv420p chosen by get_format(). Last message repeated 1 times [asf @ 0000025955e7af40] parser not found for codec wmav2, packets or times may be invalid. [asf @ 0000025955e7af40] All info found [asf @ 0000025955e7af40] After avformat_find_stream_info() pos: 191671 bytes read:196608 seeks:0 frames:58 Guessed Channel Layout for Input Stream #0.0 : stereo Input #0, asf, from 'C:\Users\Fabio\Desktop\Testes\test\a.wmv': Metadata: copyright : ChessBase GmbH WMFSDKVersion : 12.0.9600.17415 WMFSDKNeeded : 0.0.0.0000 IsVBR : 0 DeviceConformanceTemplate: MP@ML Duration: 00:00:23.08, start: 0.000000, bitrate: 526 kb/s Stream #0:0, 17, 1/1000: Audio: wmav2 (a[1][0][0] / 0x0161), 48000 Hz, stereo, fltp, 96 kb/s Stream #0:1, 41, 1/1000: Video: wmv3 (Main), 1 reference frame (WMV3 / 0x33564D57), yuv420p(left), 640x480, 0/1, 415 kb/s, 25 tbr, 1k tbn, 1k tbc Stream #0:2, 0, 1/1000: Data: none, 0/1, 10 kb/s Successfully opened the file. Parsing a group of options: output url \Users\Fabio\Desktop\Testes\test\a.wmv.tmpoutput. Applying option f (force format) with argument asf. Applying option c (codec name) with argument copy. Applying option map (set input stream mapping) with argument 0. Applying option vn (disable video) with argument 1. Applying option sn (disable subtitle) with argument 1. Applying option b:a (video bitrate (please use -b:v)) with argument 32k. Successfully parsed a group of options. Opening an output file: \Users\Fabio\Desktop\Testes\test\a.wmv.tmpoutput. [file @ 0000025955eee200] Setting default whitelist 'file,crypto' Successfully opened the file. Could not write header for output file #0 (incorrect codec parameters ?): Operation not permitted Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:2 -> #0:1 (copy) Last message repeated 1 times [AVIOContext @ 0000025955eee2c0] Statistics: 0 seeks, 1 writeouts [AVIOContext @ 0000025955e83980] Statistics: 196608 bytes read, 0 seeks
---Code:ffprobe version 4.3 Copyright (c) 2007-2020 the FFmpeg developers built with gcc 9.3.1 (GCC) 20200621 configuration: --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libsrt --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvmaf --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libaom --enable-libgsm --disable-w32threads --enable-libmfx --enable-ffnvcodec --enable-cuda-llvm --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-libopenmpt --enable-amf libavutil 56. 51.100 / 56. 51.100 libavcodec 58. 91.100 / 58. 91.100 libavformat 58. 45.100 / 58. 45.100 libavdevice 58. 10.100 / 58. 10.100 libavfilter 7. 85.100 / 7. 85.100 libswscale 5. 7.100 / 5. 7.100 libswresample 3. 7.100 / 3. 7.100 [wmv3 @ 00000180012e1440] Extra data: 8 bits left, value: 0 Input #0, asf, from 'test/a.wmv': Metadata: WMFSDKVersion : 12.0.9600.17415 WMFSDKNeeded : 0.0.0.0000 IsVBR : 0 DeviceConformanceTemplate: MP@ML Duration: 00:00:23.08, start: 0.000000, bitrate: 526 kb/s Stream #0:0: Audio: wmav2 (a[1][0][0] / 0x0161), 48000 Hz, 2 channels, fltp, 96 kb/s Stream #0:1: Video: wmv3 (Main) (WMV3 / 0x33564D57), yuv420p, 640x480, 415 kb/s, 25 tbr, 1k tbn, 1k tbc Stream #0:2: Data: none, 10 kb/s [wmv3 @ 0000018001324a80] Extra data: 8 bits left, value: 0 Unsupported codec with id 0 for input stream 2
Other
I chose to specify "-f" to facilitate other non-related parts of my flow.
Perhaps a little less cryptic description might help
but anyway try to export to mkv first, works for me witch dvb-teletext.
I'm sorry, I was trying to avoid some gray area. I legally own these files, but modifying them may always fall under that category.
Still, these video files are from chess software, they are played in sync with board movement. The thing is the chess software is dumb and proprietary and relies on a) the .wmv container and b) these data streams for (I guess) identifying the video files and syncing them to the board moves.
So as you can see, it's a very unconventional data stream. I don't need it to be parsed or reencoded or anythig, just to copy "as is".
Btw, I just tried and ffmpeg also won't put the streams into mkv!
FFMPEG - Copy empty streams
By vandalay22 in forum Video ConversionReplies: 0Last Post: 6th Nov 2019, 15:47 -
grabbing video streams ffmpeg
By lomero in forum Video Streaming DownloadingReplies: 65Last Post: 12th Oct 2019, 08:19 -
Demux all audio streams with ffmpeg
By leonsk in forum Newbie / General discussionsReplies: 8Last Post: 12th Sep 2017, 14:59 -
Why do captured Type-1 DV streams often contain corrupt audio data?
By digicube in forum Capturing and VCRReplies: 8Last Post: 16th Jul 2017, 11:28 -
ffmpeg how to copy all streams to another wrapper
By jack616 in forum Video ConversionReplies: 4Last Post: 15th Nov 2016, 14:32
