I am not exactly sure what this would be called, but VirtualDub2 when opening h264 content randomly has the video turning grey and blocking after just showing it perfectly.
I noticed that for an online IPTV recording that a 720P Stream that VDub2 seems to be the only editor that I can find so far that will actually keep A/V sync with the files.
AVIDemux loses the A/V sync all the time with them.
[Attachment 54103 - Click to enlarge]
I thought maybe it was only in VDub that this grey shows, but you see some of it in the output file. Seeking a few times clears it up but seeking very fast causes the grey to show up more often.
Probably some corruption in the file and subsequent decode errors.
You can take a look at the file details with mediainfo, also may be worth remuxing in MKVtoolnix GUI,
sometimes that helps -
Try using a different source filter. What container are the files you're having problems with? Many programs have trouble with random seeks in transport streams.
Well it turns out thst I only have a half solution now.
Using FFMPEG SOURCE with AVISynth+ for a fact fixes the grey video issue in VDub2 and output.
Now though, and same issue on Avidemux, is the audio for the first few minutes or cut segments (after commercial removal) is perfect, but the later segments randomly get a slow A/V sync where the video is fine but audio is lagging behind to where the show continues but part of commercial audio still plays.
Will a JVC VCR "Stop" Playback if the video is "too grainy" or degraded?
By timepassenger in forum Capturing and VCRReplies: 8Last Post: 2nd May 2020, 08:17 -
Why x264 "placebo" preset produce bigger file than "very slow"?
By aleaksunder in forum Video ConversionReplies: 21Last Post: 2nd Mar 2019, 08:25 -
Can the "smoothness" or "blurred" look of x265 encodes be controlled?
By MishaPrada in forum Video ConversionReplies: 11Last Post: 26th Aug 2018, 02:29 -
"Drag" transparent images over moving footage with a "mouse"
By theatermajorindistress in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2017, 13:48 -
What is the purpose of "Default" button in "Video" tab of XMedia Recode?
By MidnightUser in forum Newbie / General discussionsReplies: 1Last Post: 15th Jan 2016, 04:08
