Closed Thread
Results 1 to 10 of 10
    Jul 2020
    tehran
    Hi
    Thanks for your practical app
    I’ve been using your application for hard subtitle purposes. When I use Clear TXT Image, I receive some problems relating to the txt afterwards the OCR conversion. However, when I directly upload my image through RGB folder in Google OCR, my images are flawlessly converted to txt. So, it seems reasonable to suggest that OCR conversion can be done properly if customer images are converted to txt through Google OCR within RGB folder. Also, this process appears to be much easier than Clear TXT Image.
    Jul 2020
    tehran
    Does anyone have an opinion?
    Oct 2005
    666th portal
    this forum is not associated with google. you should probably ask them.
    Jul 2020
    tehran
    You did not understand what I meant
    I Say:
    for convert image from RGB to Clear TXT IMG this program use google ocr instead of itself
    google ocr better Output text from image
    Jul 2020
    tehran
    for example
    this take of from RGB folder:
    https://ibb.co/njWWNkM
    this result after clear txt image:
    https://ibb.co/ZxfthBb
    and this result from google ocr:
    https://ibb.co/MBSxPHP
    you can see google ocr 100% Properly OCR but when convert RGB to Clear TXT Image this image is crash
    I say Will go
    convert RGB to Clear TXT IMG and after Clear TXT IMG convert to OCR (From application,google,....) => RGB folder convert to google ocr
    That way we get less word and better way
  6. Member ricardouk's Avatar
    Mar 2005
    Portugal
    Originally Posted by elyasi View Post
    Hi
    Hi, the million dollar question... which app?
    I love it when a plan comes together!
    Jul 2020
    tehran
    Hi
    I say sample dude
    We do not need to use any any any any......... ((((application))))
    We can convert RGB folder result to => Google OCR (upload google drive (pdf) or (jpg) image and right click and open with google doc) = > Google better application for is OCR
    sample image:
    https://ibb.co/bNmPsBP
    I say better way VideoSubFinder use Google OCR Will go Clear TXT IMG and then Crash image!
    Jul 2020
    tehran
    up...
  9. Originally Posted by elyasi View Post
    Hi
    I say sample dude
    So how is this process done? Steps?
  10. Try Subtitle Edit. Uses Tesseract instead of Google but works great for sub/idx.
