Try DVDFab and copy Ultra HD Blu-rays and DVDs! Or rip iTunes movies and music! Download free trial !
  1. Whole video is like that.. decombing doesn't work, denoising either..
    Do you know a way I could do that?
  2. You can try antialiasing filters, edge interpolators .
    You probably need to resize it back to its native resolution for them to work properly. Your image looks stretched horizontally
    eg. avisynth filters
    You can play with various settings, filters and do a better job, maybe this will get you started. You might need to add some temporal antialiasing to smooth small frame to frame fluctuations (e.g. QTGMC in temporal mode)
    bicubicresize(640,480)
    awarpsharp2(depth=16)
    santiag(3,3)
    santiag(2,2)
    [Attachment 54094 - Click to enlarge]
  3. Upload a sample of your source video, un-processed and not reencoded.
  4. A few anti-aliasing filters are listed over at: http://avisynth.nl/index.php/External_filters#Anti-aliasing
    users currently on my ignore list: deadrats, Stears555
  5. @poisondeathray
    That looks great, thanks for the explanation and the code!
    @Selur
    Awesome, I'll give it a try. Thank you.
    https://www.youtube.com/watch?v=WUy2ZrgXHhs&t=71s
    This is the only source, so that's about as "un-processed and not reencoded" as it can be.
  6. Originally Posted by blitzgrey View Post
    I was hoping you had created the aliasing with some improper handling. But since you're stuck with that youtube video (already improperly deinterlaced) as your source, this might work a little better:
    SeparateFields()
    SelectOdd()
    nnedi3(dh=true)
    Santiag(3,3)
    BicubicResize(640,480)
