I think it depends on the p-code : if you upgrade your dvd player with a new firmware without changing the p-code, it should still play svcd...
Results 1 to 9 of 9
Hey Guys, thanks for your answers!
What is a p-code?
Anyone any suggestions with the bitrate?
Thanks again!
Med. -
The p-code is a number you can change with your remote control. It allows you to get more for your player : for example watching svcd. This code depends on your firmware... what's your ?
Hi !
My Philips DVD 751 says:
7.03 000320 P54 4.3.12
I'm planning to update to firmware 7.12 from
philips syndicate (btw is this the same firmware
philips would send me if I ask them to send me
the latest firmware?).
I bought the player last X-mas (in Europe).
Thanks in advance!
Med. -
Yes I think it's the same one. You can also find it here :
http://www.home.zonnet.nl/jeroenverhaar/en/index.htm
There is a guide that describes how to de the upgrade (very clear, I used this one).
Good luck.
Hi lapin !
Thanks for your answer!
I couldn't find the p-codes on the server!
Also a description what's the advantage of
each firmware is would be cool (please tell
me if you know).
Thanks!
Med. -
Hello Medical,
unfortunately, the site with the p-codes is down. but I have a printed list, so if you tell me exactly what you are looking for...
For the differents firmware I don't know. for my model there is some little differences but nothing really important. My advice, I you don't have problem with your firmware, don't change it...
Regards. -
hi everybody,
two problems with my 751 :
It plays svcd but no sound ...
It have 7.03 firmware, and no way too upgrade : "dla error"
thanks for help !!
my mail :
gargs@bigfoot.com -
Hi,
For the sound problem, you have to use analogs outputs (it doesn't work with dtgital one). For the upgrade, no idea, sorry... what new FW did you download ?
Philips 3455dvdr stays on philips logo
By vbdanl in forum DVD & Blu-ray RecordersReplies: 7Last Post: 14th Sep 2010, 11:15 -
DVD Disk Lock??? i locked my dvd player i need password! (PHILIPS DVP3520)
By kamzo91 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Aug 2010, 15:14 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
Technica PDV 751 problem
By Ulrijarn in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th May 2008, 12:53 -
Repairing the DVD Drive -- Philips PET 1000 Portable DVD Player
By ORSteve in forum Portable VideoReplies: 1Last Post: 13th Aug 2007, 13:45
