Hello,
I originally discovered I couldn't capture video via VirtualDub, but then realized I also can't capture audio from the three said programs which is probably why VirtualDub can't capture. I can hear the audio as I'm attempting to capture. All drivers are up to date. I can access all feature in the Foscusrite card. All three programs recognize both the 18i8 and the 827e, yet lock up when attempting to capture.
-Sound Forge & Vegas Pro error message: an error occurred while recording. A device is not available.
-Audacity error message: error opening recording device
OS: Win 10/64
usb soundcard: Focusrite Scarlett 18i8
pci/e video & audio card: Osprey 827e
I've tried everything I can think to get these programs to capture. Any suggestions are much appreciated.
Try uninstalling and reinstall the drivers,if that fails try the device in another computer.
Thanks johns0. I found the problem; I had all of the microphone apps turned off. I had an issue with 827e six months ago and it was recommended I turn all apps that can access the mic off. Didn't have an issue with not being able to cap from VirtualDub, or any of the audio programs at that time. Turned them on and now I can cap with all desired programs.
I had that issue as well,couldn't use my headset on discord cause i turned off apps using microphone as well,glad you found the problem.
why does not sound forge 12 pro detect wasapi ?
By rama in forum AudioReplies: 2Last Post: 31st Dec 2018, 01:36 -
raw avi file has audio, no audio in Vegas Pro 12
By clashradio in forum Capturing and VCRReplies: 6Last Post: 9th Oct 2017, 18:29 -
Adding sound effects in Vegas pro 14
By kwanami in forum EditingReplies: 2Last Post: 1st Sep 2017, 00:37 -
5.1 AC3 audio.. no sound from left channel in VLC or mpv, fine in Audacity
By arcooke in forum AudioReplies: 1Last Post: 26th Dec 2016, 03:53 -
How to remove click and crackle from a VHS audio using Sound Forge?
By KortschKo in forum RestorationReplies: 7Last Post: 16th Feb 2016, 19:57
