Hi all. I've been usin desktop pc for editing for ovr year now, but I need now laptop, because I'm going abroad for about 6 months. I need some laptop with specs that can edit mostly 1080p and sometimes 4k. I don't care if it takes too long to render or if sometimes playback is not smooth. As long as it can do the job (specialy with 4k editing, effects and color grade). Now I did some research, most people say 16g ram, i7 7th gen, gtx 1050 is not enough for 4k. But what if I edit and color grade in proxy, would it be ok then? And I am thinking buying used laptop, not new.
I found these two laptops:
Asus Rog Zephyrus Ga502du AMD Ryzen 7 3750H, Quad-core, 2.3 GHz / 4.0 GHz, 6 MB cache, 16 GB DDR4 (2400 MHz), 24 GB max installable RAM, NVIDIA GeForce GTX 1660 Ti with Max-Q, 6 GB GDDR6, Storage: 512 GB SSD, Screen size: 15.6", Screen type: LED, Resolution: Full HD 1920 x 1080p, Screen features: 120 Hz display,
Dell Alienware M17x R3, i7-6820HK 2.7GHz (3.6GHz Turbo), 16GB DDR4 RAM, 180GB SSD + 1TB Hard Drives, 17.3" 4K LED Display, Dual Graphics: 1. Intel HD530 2. NVIDIA GTX 980M
Both 1000€ used. Which one of these is more suitable? Thanks
	here's the recommended / minimum system requirements for DaVinci resolve - https://www.richardlackey.com/davinci-resolve-system-requirements/
	Both of those systems are lacking in different ways. Either of them will probably let you get by if you're using proxies. They can both become obsolete very quickly when Blackmagic updates.
  DaVinci Resolve, Youtube and HD?By Guernsey in forum Newbie / General discussionsReplies: 3Last Post: 3rd May 2020, 16:02
  Davinci Resolve + Rx 5700 TxBy VVK in forum EditingReplies: 2Last Post: 2nd Feb 2020, 07:38
  So many films are using Davinci Resolve now!By joejonas in forum Latest Video NewsReplies: 4Last Post: 8th Dec 2019, 10:40
  Which if any version of DaVinci Resolve works with XP 32 bit?By brassplyer in forum EditingReplies: 3Last Post: 9th Jan 2017, 16:19
  Davinci Resolve 12 NLEBy SameSelf in forum EditingReplies: 11Last Post: 7th Feb 2016, 10:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
