I have a commercial blu-ray disk labelled as 1080i, and MediaInfo says the m2ts files are "Interleaved fields, Scan order: Top Field First". I have encoded the disk using AnyDVD and VidCoder with all video filters set to off (including deinterlace = off). The resultant MKV file is clearly interlaced (with combing), but MediaInfo says it is progressive and tsMuxer says the resolution is 1920:1080p, so my TV does not deinterlace the picture.
Why is the file labelled progressive after encoding by VidCoder with all filters off? Is there any way to label the MKV file as interlaced?
I could encode using Vidcoder with deinterlace on, but the result is likely to be inferior to having my TV deinterlace the picture.
@barmah
I am not familiar with Vidcoder, but from how you describe it I conclude that Vidcoder encoded your interlaced video source as progressive.
If so, it is simply wrong and the worst you can do to your interlaced source. Check the settings of Vidcoder, there should be an option to force interlaced encoding and select the field order. If not, you should select a deinterlacer or bobber instead and encode as progressive. Obviously this is not what you want though for the reason you mention. -
@Sharc: VidCoder is just a convenient front-end for Handbrake.
The problem of an interlaced file being incorrectly labelled as progressive is solved by using Handbrake (not VidCoder): in the Filters tab set everything to off; in the Video tab set fps to "Same as source" with "Constant Framerate", and in Advanced Options add :tff or :bff (top or bottom frame first can be obtained from MediaInfo set to View/HTML).
How to correct an interlaced video converted to progressive?
By klode in forum RestorationReplies: 2Last Post: 1st Mar 2019, 11:21 -
FFV1 encodes incorrectly reported as Progressive, is actually interlaced
By Killer3737 in forum Video ConversionReplies: 29Last Post: 23rd Aug 2018, 14:34 -
Remove interlaced artifacts on progressive video.
By TempUser_ in forum Video ConversionReplies: 4Last Post: 18th Jul 2018, 12:38 -
Resize interlaced video without making it progressive
By xMike in forum EditingReplies: 5Last Post: 31st May 2018, 09:26 -
How do you make a NTSC interlaced DVD video progressive?
By runlouierun in forum Video ConversionReplies: 54Last Post: 22nd Jun 2017, 22:27
