Having spent many years using TMPGEnc products to create DVD's,thought i would have a go at authoring a BDMV Bluray using Authoring Works 6
i used TMPGEnc Video Mastering Works 6 to create two titles to export to Authoring works,both titles are smart render compatible according to Authoring works
[Attachment 54080 - Click to enlarge]
[Attachment 54081 - Click to enlarge]
authored disc structure plays perfectly through VLC media player,used ImgBurn to burn project to BD-R
all going well so far,that is until i put said disc into Playstation 4,then i get Unsupported Disc in PS4
made 2 discs so far,both turned out to be coasters
cant fathom out what could be wrong
PS using Verbatim 25GB BD-R's,never had a problem with using their discs,made hundreds of DVD's on Verbatims
doing my head in spent 3 days at this
Results 1 to 11 of 11
Do you have another blu-ray player you can try the discs with?
Do they play in the ps3?
verbatim makes cheap bdr. re-used dvd making tech. called lth bdr, they aren't compatible with all drives. check to see what you have.
Ive burned all my TMPGEnc Authoring Works 6 folders with imgburn and they all play with no issues on any blu-ray player i tried.
TMPGEnc Authoring Works 5 Menu Help
By hurricane1951 in forum Authoring (Blu-ray)Replies: 3Last Post: 26th Feb 2022, 14:28 -
TMPGEnc Authoring Works and Photoshop Menus
By CameraRick in forum Authoring (Blu-ray)Replies: 3Last Post: 3rd Feb 2021, 00:28 -
Problem with TMPGEnc Authoring works 6
By pablur in forum Authoring (Blu-ray)Replies: 3Last Post: 9th May 2019, 05:49 -
TMPGENC Authoring Works 5 VBR or CBR
By jcool26 in forum Authoring (DVD)Replies: 4Last Post: 5th Jul 2016, 20:04 -
TMPGEnc Authoring Works 5 Problem
By Mart7 in forum Newbie / General discussionsReplies: 13Last Post: 15th Aug 2015, 12:45
