Looking for a program like MP3 Trim that lets you adjust vol levels losslessly, but without opening it afresh for every file.
Also not Foobar as it decides how much to alter.
Ideally I could drag an mp3 file in, then set + or - db manually.
Thanks.
I think mp3gain does what you want.
Foobar2000 Replaygain 89dB reference level is configurable (also works for mp4/m4a).
mp3DirectCut allows you to cut and change amplitude of blocks within the mp3 file (lossless operation).
Normalizing MP3 Audio Volume on Video Files?
By MadMaxnightRider in forum AudioReplies: 16Last Post: 22nd Feb 2020, 05:26 -
Software that change change speed of MPG (without converting)?
By guy24s in forum EditingReplies: 10Last Post: 19th Dec 2017, 05:49 -
Cannot change the sound volume when I connected ipad with an AAXA M6 projec
By pixelPIC in forum Portable VideoReplies: 0Last Post: 31st Aug 2017, 17:46 -
Volume Level Equalizing a Bunch of MP3 files. How to do it?
By cornemuse in forum AudioReplies: 19Last Post: 21st Sep 2016, 14:51 -
Can a mono mp3 file be losslessly repackaged to joint stereo mp3?
By Condorcet in forum AudioReplies: 14Last Post: 9th Jul 2016, 10:46
