Greetings everyone,
I am trying to convert couple of VHS tapes to digital format using capture card and OBS. I've encountered a problem with all my tapes playing in a shaky and wavy manner. Here is an example: https://youtu.be/_JDWpw-dxoo
Is this problem from my VHS player or its from the capture device?
Capture card/device:
* EasyCap
* LG VHS Player: GL182W
Thanks in advance![]()
Results 1 to 16 of 16
Firstly, OBS is NOT a capture program. It is a screen-capture program. There is a difference.
Use the software that comes with the capture device as a starting point and upload a sample capture from that.
Your tape has tracking issues and they should be fixed BEFORE you capture anything. -
How does the tape play on your tv from your vhs?
I'm surprised no one has addressed the elephant in the room. Even once the OP gets the VCR and capture method solved, he/she's still working what the notorious EasyCap!
^^ Well sometimes they work
To the OP. To get screen-capture (I do assume that OBS can not do normal transfer) there has to be a picture on the screen. No capture device can do that without capture software. So something does not add up here.
Try virtualdub for the capture. No need for any licence key here.
But my money is on a bad vcr. -
If Videohelp gets a dollar out of everyone who buys the easycrap and comes here to complain about the problems they will be able to buy youtube.
I would say a combination of all, easycrap, VHScrap, OBScrap, The OP needs to do some learning about capturing analog video the proper way, There are nice materials to read at digitalfaq.com just look for the right subforum. -
Drivers for usb devices have to be installed in a certain way (typically BEFORE you plug it in for the first time) - there should have been instructions with the device.
You have also not stated your OS. Windows 10 ?. These easycaps are notorious for poor driver support for OS after XP.
But do try what I suggested to see if you can get a clear picture in preview using vdub.
What do you consider 'reasonable priced' ? -
+1
As stated in numerous other threads, any type of quality requires the right equipment which costs $$$. Right now you're in the poor to fair stage with your VCR and capture device. If you get lucky and find a better VCR and capture device or a working VHS/DVD combo for less than a few hundred dollars you may be able to get into fair to good quality. Otherwise, you're probably looking at a minimum ~$300-400 to get out of the poor to fair category. -
- VCR: lousy
- Easycap: literally the worst cheap Chinese capture device made
- OBS: the wrong software for analog capture
Essentially you're doing everything wrong.
- Good VCR: $500+ (up to $1k)
- A bare minimum form of TBC: $125+ ... note the term "minimum" here, as there will be a capture fail rate the more minimalist/cheap you go; there are trade-offs in quality of the image, and the capture experience; ideal/best TBC $1k+
- Good capture card: $100+
- Good capture software: $FREE, VirtualDub 1.9.x
Buy it, use it, resell it.Want my help? Ask here! (not via PM!)
Can a 480p capture device capture 640x480 well? Seeking a suitable device
By Neil-Betamax in forum Newbie / General discussionsReplies: 28Last Post: 21st Apr 2020, 10:56 -
Device not detected on VHS to USB Capture-Converter
By Anonymous754 in forum Capturing and VCRReplies: 10Last Post: 26th Jun 2017, 07:46 -
Faulty usb device or cure with a TBC
By DB83 in forum Capturing and VCRReplies: 26Last Post: 18th Nov 2016, 10:08 -
Best Complete Device Set for Old VHS Tape Capture
By lplp in forum Capturing and VCRReplies: 6Last Post: 27th Nov 2015, 11:14 -
What’s the best VHS capture device I can buy with $200?
By nqservices in forum Capturing and VCRReplies: 56Last Post: 26th Nov 2015, 08:25
