Results 1 to 24 of 24
  1. I have a Win7. 64 Bit DeskTop and a CellPhone that Records Audio.
    The Audio Format is .opus.
    It Says it is 44k for Bit Rate.
    But after I Bring it into MediaInfo on my DeskTop it Says Bit Rate 45.5 kbps.
    What am I not understanding?
    Mar 2008
    Are you having a problem with this audio? Upload a small sample file
  3. Member Cornucopia's Avatar
    Why are you asking this same question again?
  4. Originally Posted by Cornucopia View Post
    Yes, this does seem like déjà vu, and from less than a month ago:
    Audio Help
  5. I just wanted to know why when I Pick the 44k Recording from the Record Options List it does not Record in 44k?
    I open it in MediaInfo and it Says 48kHz this is the FREQ. but the Bit Rate Says 45.5 kbps?
  6. Member Cornucopia's Avatar
    How about you post the settings that you MEANT to use in your encoder app (screenshot), and upload a clip of the file in question, and we can analyze it to see whether something went wrong, or whether things are being misinterpreted.
  7. Here is the Readout in MediaInfor for my Recording
    Format : Opus
    Duration : 5s 297ms
    Overall bit rate : 45.5 Kbps
    Channel(s) : 1 channel
    Channel positions : Front: C
    Sampling rate : 48.0 KHz
    I go to Upload my Recording to this WebSite and after I Click Brows I see my File is in the Brows Box.
    I see nothing that Says Upload so I Click Close Window.
    And it takes me Back to this Window Here.
    But in my Settings on my Phone I Pick 44k for the Large File Size.
    But as you see MediaInfor Says Bit Rate is 45.5 kbps.
    I did not know what this was doing?
    Mar 2008
    This is where you upload files to the thread
  9. Ok I Uploaded a File.
    Now you can see what I am Talking about.
  10. Member Cornucopia's Avatar
    Where?
  11. I Clicked on Upload File.
    Then I Click Brows and Open the File.
    Then to the Right of the Brows Box it Says Upload and I Click it.
    Then I Click Close Window.
    Am I doing it Wrong?
  12. You didn't wait long enough. You have to wait for the "file uploaded" message before closing the dialog.
  13. I found out what is happening.
    After I Click Brows and Click my File I Click Open.
    Then on the File Upload Page I Click Upload.
    But this is what MediaInfo Tells me about my File
    Format : Opus
    Duration : 5s 297ms
    I just do not know why Overall bit rate Says 45.5 Kbps when I pick 44k in my Audio Options on my Phone?
    Then a screen Tells me Upload Error The File is not Supported.
    Mar 2008
    Format : Opus
    Duration : 5s 297ms
    What is the format of your file? You could always zip it and upload that
  15. .opus isn't one of the accepted file types supported by the uploader here. Either mux it into a different container (.mka for example) or zip it up and upload the zip file.
  16. The File Format is .opus
    it is an Audio Format.
  17. Member Cornucopia's Avatar
    Yeah, we understood that, multiple times. Are you gonna post a zipped copy?
    And what about the app that you encoded this file with and what settings you used - NOT just how it seemed to end up. Still waiting on that.
  18. I can not Upload anything.
    Maybe it is me but thanks for the Time.
  19. Originally Posted by biferi View Post
    Then upload to a file sharing site and provide the link. You can use Amazon Prime, Mediafire, Google Drive, and dozens of others. You don't have to upload to this site (which I have found is not very good at letting you upload files).
    Mar 2008
    This thread is like Alice in Wonderland / Through the Looking Glass
  21. Originally Posted by davexnet View Post
    No. That book was a good read; this thread is a total waste of time.
  22. Member
    Mar 2008
    No disrespect to Mr. Carrolls book - not disparaging that, it's a classic
    I just meant from the slightly surreal nature of the thing, sorry to have offended you
  23. DECEASED
    Jun 2009
    Heaven
    This thread should be locked and the OP should be banned
    "Programmers are human-shaped machines that transform alcohol into bugs."
  24. Originally Posted by davexnet View Post
    You didn't offend me in the least. I guess I should have added a smiley face to my post. My "no" was only meant to mean that I loved reading that book, but this thread is no longer worth clicking on to see the updates, and therefore is unlike "Alice" which was fun to read.
