hello all ... im looking for software for this device that can capture in mpeg4 for my needs, any help would be great
Try vdub, if you can't get vdub to access the crossbar of your card then you may need Aja proprietary software, In any case capturing to h.264 on the fly is not recommended, Capture lossless, and encode later.
I don't know of a way to directly capture to h.264 with the LHi either. Their software is pretty much geared toward lossless codecs. Probably best to do a lossless capture and then reencode it later and dump the original huge file.
Need specific DV capture software...
By llek in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 1st Jul 2020, 14:08 -
Mac Capture Software
By Smack2k in forum CapturingReplies: 4Last Post: 18th Dec 2019, 07:22 -
Capture software recommendation
By freddy73 in forum CapturingReplies: 2Last Post: 8th Feb 2017, 17:35 -
Best MPEG-2 capture software?
By premiumcapture in forum CapturingReplies: 12Last Post: 11th Nov 2015, 16:32 -
Best Mac DV Capture Software?
By NA87 in forum MacReplies: 3Last Post: 23rd Sep 2015, 21:16
