I am trying to render a 45 min long file in Vegas as a blu-ray compatible file (m2v) and it keeps stopping at ca 85 %. The resulting file is ca 7 GB. Is there a limit to how large a file it can render?
Kal
Do you have your GPU acceleration enabled? I actually had to turn mine off because the render kept locking up. Once it was set to off rendered like a champ. Don't know why as I have a pretty decent GPU (GeForce GTX-1080 Ti).
Kal
Ok now I'm confused; in Options-Preferences-Video tab-"GPU acceleration of video processing" you can either have Off or enabled (which will display your make/model of GPU as long as Vegas recognizes it). Since I have a decent GPU, and Vegas recognizes it, shouldn't I have it set to On? But when it's On my render freezes. If Vegas' GPU render sucks, why does it crash when I have "GPU acceleration of video processing" set to my GTX 1080Ti?
VEGAS Pro 17 not rendering AVC/MVC codec
By Risto15 in forum Newbie / General discussionsReplies: 4Last Post: 22nd May 2020, 22:20 -
Rendering Problems in Sony Vegas Pro
By CaptainCatholic587 in forum EditingReplies: 7Last Post: 22nd Apr 2020, 02:33 -
vegas pro applies deinterlacing before rendering ?
By codemaster in forum EditingReplies: 3Last Post: 30th Jun 2016, 01:07 -
Vegas: rendering in wrong Frame size (Batch render)
By AdrianoX in forum EditingReplies: 0Last Post: 29th Jun 2016, 00:13 -
Sony-Vegas Pro 13.0 - Rendering issue on Windows 7.
By Ziplo in forum EditingReplies: 3Last Post: 17th Dec 2015, 15:00
. Just like you I have the GeForce GTX-1080 Ti.
