I have a mpg file in VCD format. I want to add a subtitle to that mpg. I used a VDUBs filter Textsub(for use with srt or sub). It was not possible to save it in mpg format. In virtualdub i only could save in avi format. So i frameserved to TMPGENC. But in tmpgenc i got the message that the videofile is unsupported. I read the howto section. They say exact the same what i did.
Quite easy. I just want to add subtitles to my mpg's. I read the howto section. It says that i can open avi-mpg-asf files with vdub, and then frameserve to TmpENc. But i think it's only possible to frameserve to tmpgenc with avi files. So there is no way for me more to add subtitles to my mpegs.
Unless somebody knows a way. -
Have you installed VirtualDubs frameserver handle? If you can frameserve an avi, you can do the same for an VCD mpg. You might have to change the priority settings in TMPGEnc to make it accept .vdr as input.
yeap remember that aviproxy must be off and u must install the handler. Just incase, i had problems frameserving with virtualdub to tmpeg. I recomend u getting vdub v.1.4.9 thats if v.1.4.10 does not work. good luck
I used vdub 1.4.9 now (and tmpgenc 12a because I had some problems with the newest version) and everything works now
Thanks..
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 11:39 -
Just got me a Screenplay TV link Director and noticed it doesnt show Subtit
By Adam901 in forum Media Center PC / MediaCentersReplies: 2Last Post: 30th Mar 2011, 09:21 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
