  1. I'm converting English SRT subtitles downloaded from a streaming site to Bluray .sup format. Do I need to change the encoding format such as to UTF-8 for example or do I not need to bother?
  2. load you subtitle and try .. easySup ... I don't think it's necessary
    責任者-MDX
  3. Member Ennio's Avatar
    May 2005
    Netherlands
    I like SubtitleEdit better. IIRC easySup suffers from a 24fps bug and IMO SubtitleEdit makes a better picture.
  4. What's the 24fps bug?
  5. Member Ennio's Avatar
    May 2005
    Netherlands
    After creating SUP for 24fps, subtitles display go out of sync. IIRC it will act as 23.976fps SUP.
    There is a remedy to it by importing it into BDSup2Sub, set both in- and output framerate to 24 fps and export again. Then you're good to go.
  6. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
