I'm trying to copy material from my DVR to my PC running Windows 10. Was able to do this for a number of years using an Asus PC with a Blackmagic Intensity Pro. Was able to capture to .avi with AmeRecTV using Lagarith. A few quick edits in Vegas Pro 17 and then authoring in TMPGEnc Authoring Works.
All of that worked fine until the PC completely died. I replaced it with an "upgrade", an i7 Dell. The Intensity Pro wouldn't work in the Dell so after a bit of research I got a Startech PEXHDCAP60L2 card. The only capture software I've been able to get to work is Stream Catcher downloaded from the Startech site. It only saves in h.264 MP4, which didn't seem that it should be a problem, but in Vegas I'm noticing a gradual drift of audio sync and a slight occasional jerkiness. Tried the fix suggested here with no success: https://steamcommunity.com/app/689790/discussions/0/1694920442946536734/
Any thoughts on what I need to do differently in capture setting, Vegas settings, etc.? Would I fare better with a different device? Given the previous success with the Intensity Pro I was considering trying an Intensity Shuttle for USB 3.0. The PC DOES have USB 3.0 ports, but I'm hesitant due to the incompatibility of Dell and the Intensity Pro card. I understand that the requirements for getting an internal card to work might not necessarily apply to an external device, but am still hesitant. Even if it works it might not solve my problem.
Thanks in advance for any help. All suggestions appreciated.
				Results 1 to 1 of 1
  DV File Audio Video Sync Issues - Audio DriftBy Christina in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 2nd Mar 2020, 07:58
  HEVC Audio sync issues.By DonaldsonAC in forum Newbie / General discussionsReplies: 0Last Post: 6th Nov 2018, 07:52
  AVStoDVD audio sync issuesBy Imy in forum Video ConversionReplies: 16Last Post: 24th Jan 2018, 12:19
  Audio sync issues - further assistance please.By mclosi in forum Capturing and VCRReplies: 1Last Post: 1st Oct 2016, 13:13
  HD PVR 2 Capture card has audio issues. Any solutions?By super6646 in forum Capturing and VCRReplies: 0Last Post: 17th Aug 2016, 19:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
