I made a video of a person giving a speech. The originals are shot in mp4.
the speaker coughs at one point
I am using Linux Mint 19.1 with avidemux.
I need to convert the video from .mkv to other formats to upload it on the internet
so I think the format may effect how it can be edited and saved.
when I have attempted to cut the cough out, avidemux tells me the cut is not on a keyframe so the video will be corrupted. If I change the format, I am able to make the cut in avidemux but the video won't play, so must be deleted.
I would like to cut the cough section out but if that is not possible, at least suppress the sound.
Any help appreciated.
The video and audio are two separate streams inside the file. You can open the file in Audacity (audio editor) with the FFmpeg
add-on enabled and it will allow you to work on just the audio. When you've suppressed the cough you save it as a new
audio file and recombine it with the original video to a new file
If you'd rather edit the video and audio, you'll need something like VideoRedo ($$),
comes with a trial but not sure of the limitations
https://www.videoredo.com/en/index.htm -
Depending on how obvious the cough is physically, you might be able to get away with not even editing the video, but instead just dip/mute the audio.
Deleting CEA-608 (EIA-608) captions from a H.264 video file
By Sviests in forum SubtitleReplies: 31Last Post: 22nd May 2021, 01:15 -
Deleting info on video black bars
By carlmart in forum Video ConversionReplies: 2Last Post: 11th Dec 2017, 12:05 -
Deleting bad frames using Avisynth
By pooksahib in forum Video ConversionReplies: 11Last Post: 8th Oct 2017, 10:26 -
Deleting lines in a subtitle makes it useless?
By Kracov in forum SubtitleReplies: 3Last Post: 2nd Sep 2016, 00:18 -
Deleting files but creating shortcuts instead
By johns0 in forum ComputerReplies: 5Last Post: 22nd Nov 2015, 05:45
