Have a 400GB folder of PNG files that I want to make into a smaller video, obviously, but not sure how to go about it. I understand that I an feed the files into a program like avidemux, but what settings do I use, do the PNG files have information that tell the program how to join and compress the files into a video? Any advice? Thanks.
Results 1 to 9 of 9
If they're sequentially numbered (named) you can open them in VirtualDub2 (free), specify a video codec, and save as video.
You mean, you want to create a single video with all those PNG files, each being converted to a few frames of video ? For what purpose ? Should all the picures be included ? 400GB is huge... What is their resolution ? Do you want / need to keep the same resolution for the video ? Do the pictures have to be in a particular order, or their current alphanumeric order is fine ?
Using Avisynth and ImageSource(), with a good text editor (like Notepad2, or TEDNotepad which has more features, or perhaps it could be done directly within AVSPMod, a special editor which allows to visualize the video output of AVS scripts), you could fine-tune the output to your liking, for instance adding a fade-in and fade-out to each picture. I don't know how well an Avisynth script would work with hundreds or thousands of pictures, though. -
PNG is a lossless compression, and is an intra-frame codec. It averages ~2.5:1 compression. It commonly would be expected that a video file which used hd files and is compressed with h264 might be compressed to ~300:1 and be 5GB. Working backward, one can see that an equivalent source png sequence would amount to ~600GB.
In other words, if you are rendering a unique animation to png image sequence (a common best practice among animators, for workflow efficiency and quality control reasons), it would be perfectly normal and expected to fill a folder to that capacity, prior to final video distribution encoding.
ScottLast edited by Cornucopia; 7th Jul 2020 at 00:52.
Alright then. And so, if that's indeed similar to the situation exposed in this thread (which is rather fuzzy as it is), what are the best practices among animators to convert PNG pictures to video ? I would guess that professional animators use professional software... And I would guess that a professional wouldn't ask such a question...
I was using AI software to enhance/upscale a video. The program allows you to output to PNG or TIFF images(the native video output is x263 for reasons best known to the developer) which then need to be converted back into video and obviously compressed as well. I used virtualdub2 to convert/compress to x265 in the end.
Hi everyone,
I’ve worked on something similar before. For large PNG sequences, I’ve found that using tools like VirtualDub2 or FFmpeg works well for converting to video. Before starting, I also compress the PNG files using this PNG Compressor tool to save space without losing quality, which makes the process smoother. It’s quite helpful when working with huge image folders.Last edited by salini; 6th Jan 2025 at 23:26.
Cover.png for MKV files gone black in Explorer.
By Tombless in forum Newbie / General discussionsReplies: 17Last Post: 9th Mar 2020, 05:16 -
Quick convert ttml2 with png files to srt
By olpdog in forum SubtitleReplies: 0Last Post: 21st Jun 2019, 18:45 -
Converting TTML2+PNG Subtitles to BDN(XML+PNG)
By MounaLafi in forum SubtitleReplies: 6Last Post: 25th Jan 2019, 06:48 -
Combining multiple Video files and compressing
By unknown in forum Newbie / General discussionsReplies: 10Last Post: 8th Nov 2018, 02:46 -
How do I rip DVD subtitles to PNG, JPG, or BMP files?
By Videogamer555 in forum SubtitleReplies: 12Last Post: 24th Oct 2015, 23:11
