I'm trying to use Amarec to capture VHS video via an EasyCap USB video interface. Whenever I record I get a warning message: "the frame rate of the video capture card does not suit a preset value". I also notice that frames are being dropped while recording.
I've tried setting the framerate to both 30fps and 25fps in Settings, but still get the warning. The source is a pre-recorded UK PAL VHS tape, played back on a Toshiba UK VHS player, connected to the USB capture card via a Panasonic Blu Ray/DVD recorder for TBC.
Any idea what I can do to fix this?
Set the frame rate to 999 and let it sort itself out depending upon the input.
Try setting up a preset with your preferred settings. With my Hauppauge USB Live2, a lot of the settings don't seem to be honoured except when selecting a preset with those settings. (Preset #1 seems to be the preset that is automatically loaded when you start AmarecTV)"Well, my days of not taking you seriously are certainly coming to a middle." - Captain Malcolm Reynolds
Variabel frame rate / constant frame rate problem with free version of VSDC
By danielschut in forum Newbie / General discussionsReplies: 6Last Post: 11th Jun 2020, 02:50 -
transcode Variable Frame Rate (VFR) AVC video to Constant Frame rate (CFR)
By hydra3333 in forum Video ConversionReplies: 2Last Post: 4th Mar 2018, 05:01 -
Frame Rate, Bitrates ans Frame by frame comparison
By novreis in forum Newbie / General discussionsReplies: 1Last Post: 5th Feb 2018, 17:40 -
Variable frame rate into constant frame rate without re-encoding
By DunnoNo in forum Newbie / General discussionsReplies: 8Last Post: 21st Dec 2017, 11:05 -
How to Determine Original DVD Frame Rate & Frame Type
By lomaidala in forum Video ConversionReplies: 30Last Post: 3rd Jul 2017, 07:42
