First, I want to apologize if you don't understand what I say, English is not my language.
Second, I looking everywhere for info about to add mp4 output support on x264. I have tried like this, this, this, or this, but nothing works, some guides are very old or are not show detailed process.
Supposedly, when it run ./configure in MinGW, GPAC (which I also have installed on PC) or Lsmash are automatically detected when the source code files are in the workplace, but on prompt it keeps say "mp4: no".
What exactly should I do?
Results 1 to 18 of 18
Why compile by yourself?
For simple mp4 support you could use a FFmpeg static build (for Windows: https://ffmpeg.zeranoe.com/builds/) and a Gui, g.e. my clever FFmpeg-GUI.Last edited by ProWo; 30th Jun 2020 at 10:04.
I suppose you know about doing basics and encoding *.264 then muxing it in mp4. If yes , just disregard this. mp4box-gpac you can install this way:
Code:sudo apt-get install subversion sudo svn co https://svn.code.sf.net/p/gpac/code/trunk/gpac gpac cd gpac sudo /configure --disable-opengl --use-js=no --use-ft=no --use-jpeg=no --use-png=no --use-faad=no --use-mad=no --use-xvid=no --use-ffmpeg=no --use-ogg=no --use-vorbis=no --use-theora=no –use-openjpeg=no sudo make sudo make install cp bin/gcc/libgpac.so /usr/lib
Although it's something any mortal would do, the thing is I want to build an x264 bin (from VideoLan source code) with mp4 output support because official releases have it disabled by default. Even if FFmpeg is very complete, I don't want to use it for my H264 encodes. Also I try to learn something different and I don't know.
This is not clear to me. Do all of that, is the same as doing it using "git clone https://github.com/gpac/gpac.git" before run ./configure and make? Or are the specific files needed for x264 to detect GPAC before run ./configure and make? BTW, I forgot to mention that I use MinGW and trying to do it from WIndows 10, although I have a VM with Ubuntu, I'm not sure if it's possible to cross-compile x264 for Windows.Last edited by naoto89; 30th Jun 2020 at 22:58.
"Zeroth" of all: I recommend that you DO NOT USE gpac because it's bloatware, but I cannot stop you from using it anywaySupposedly, when it run ./configure in MinGW, GPAC (which I also have installed on PC) or Lsmash are automatically detected when the source code files are in the workplace, but on prompt it keeps say "mp4: no".
I presume you mean you do have compiled (and "installed") GPAC or L-Smash, instead of just having "their source-code in the workplace"GPAC (which I also have installed on PC) or Lsmash are automatically detected when the source code files are in the workplace
And in this case, you should "say" to x264's ./configure the exact paths to L-Smash's include files + lib files
—otherwise ./configure will ignore your instruction to add an MP4 muxer to the final. EXE.
So, give a try to something like this:
NOTICE: I have never tried to compile x264.exe with anything besides Avisynth support,Code:./configure --blah-blah-blah CPPFLAGS="-I/path-to-L-Smash/include" LDFLAGS="-L/path-to-L-Smash/lib" --blah-blah-blah make
because I don't even use the built-in MKV and FLV muxers of x264,
so take this suggestion with a grain of salt and play at your own risk
"Programmers are human-shaped machines that transform alcohol into bugs." -
About that of "installed" I meant that I downloaded the latest GPAC installer and after added "C:\Program Files (x86)\GPAC" to PATH (or it says in this guide). I also downloaded the source code but it's in workplace where I try to compile with x264. In any case, I tried to do it both ways but I never knew what the error was. In the case of L-Smash, I just downloaded the source code but I didn't know how to call the files and I couldn't find a guide about it (and even if there are guides, surely the language is Russian, Chinese or Japanese).
Ok, I tried to compile with L-Smash following the example above and detects it, but now the problem is an error and it can't compile.
On MSYS2-MinGW32
On MinGW32Code:checking for -Werror=unknown-warning-option... no Failed commandline was: -------------------------------------------------- gcc conftest.c -Wall -I. -I$(SRCPATH) -I../l-smash/tmpbuild/include -D_POSIX_C_SOURCE=200112L -Werror=unknown-warning-option -L../l-smash/tmpbuild/lib -o conftest cc1.exe: error: '-Werror=unknown-warning-option': no option '-Wunknown-warning-option' -------------------------------------------------- Failed program was: -------------------------------------------------- int main (void) { return 0; } -------------------------------------------------- checking for -Werror=unknown-attributes... no Failed commandline was: -------------------------------------------------- gcc conftest.c -Wall -I. -I$(SRCPATH) -I../l-smash/tmpbuild/include -D_POSIX_C_SOURCE=200112L -Werror=unknown-attributes -L../l-smash/tmpbuild/lib -o conftest cc1.exe: error: '-Werror=unknown-attributes': no option '-Wunknown-attributes'; did you mean '-Wno-attributes'? -------------------------------------------------- Failed program was: -------------------------------------------------- int main (void) { return 0; } -------------------------------------------------- checking for -Werror=attributes... yes checking for -Werror=ignored-attributes... yes checking for -lshell32... yes checking for -S... no Failed commandline was: -------------------------------------------------- gcc conftest.c -m64 -Wall -I. -I$(SRCPATH) -I../l-smash/tmpbuild/include -D_POSIX_C_SOURCE=200112L -Werror=attributes -Werror=ignored-attributes -S -lshell32 -m64 -L../l-smash/tmpbuild/lib -o conftest cc1.exe: sorry, unimplemented: 64-bit mode not compiled in -------------------------------------------------- Failed program was: -------------------------------------------------- int main (void) { return 0; } -------------------------------------------------- checking for -Wl,--high-entropy-va... no Failed commandline was: -------------------------------------------------- gcc conftest.c -m64 -Wall -I. -I$(SRCPATH) -I../l-smash/tmpbuild/include -D_POSIX_C_SOURCE=200112L -Werror=attributes -Werror=ignored-attributes -Wl,--high-entropy-va -lshell32 -m64 -L../l-smash/tmpbuild/lib -o conftest cc1.exe: sorry, unimplemented: 64-bit mode not compiled in -------------------------------------------------- Failed program was: -------------------------------------------------- int main (void) { return 0; } -------------------------------------------------- checking whether windres works... no Failed commandline was: -------------------------------------------------- windres --target=pe-x86-64 -o conftest.o conftest.rc C:\msys64\mingw32\bin\windres.exe: Can't detect target endianness and architecture. -------------------------------------------------- Failed program was: -------------------------------------------------- 0 RCDATA {0} -------------------------------------------------- checking whether !WINAPI_FAMILY_PARTITION(WINAPI_PARTITION_DESKTOP) is true... no -------------------------------------------------- cc1.exe: sorry, unimplemented: 64-bit mode not compiled in -------------------------------------------------- Failed program was: -------------------------------------------------- #include <winapifamily.h> #if !(!WINAPI_FAMILY_PARTITION(WINAPI_PARTITION_DESKTOP)) #error #endif -------------------------------------------------- x264 configure script Command line options: "--enable-shared" "--enable-static" "--bit-depth=8" "--extra-cflags=-I../l-smash/tmpbuild/include" "--extra-ldflags=-L../l-smash/tmpbuild/lib" checking whether gcc works... no Failed commandline was: -------------------------------------------------- gcc conftest.c -m64 -Wall -I. -I$(SRCPATH) -I../l-smash/tmpbuild/include -D_POSIX_C_SOURCE=200112L -Werror=attributes -Werror=ignored-attributes -lshell32 -Wl,--image-base,0x140000000 -m64 -L../l-smash/tmpbuild/lib -Wl,--dynamicbase,--nxcompat,--tsaware -o conftest cc1.exe: sorry, unimplemented: 64-bit mode not compiled in -------------------------------------------------- Failed program was: -------------------------------------------------- int main (void) { return 0; } -------------------------------------------------- DIED: No working C compiler found.
Code:checking for -Werror=unknown-warning-option... no Failed commandline was: -------------------------------------------------- gcc conftest.c -Wall -I. -I$(SRCPATH) -I../l-smash/tmpbuild/include -D_POSIX_C_SOURCE=200112L -Werror=unknown-warning-option -L../l-smash/tmpbuild/lib -o conftest cc1.exe: error: '-Werror=unknown-warning-option': no option -Wunknown-warning-option -------------------------------------------------- Failed program was: -------------------------------------------------- int main (void) { return 0; } -------------------------------------------------- checking for -Werror=unknown-attributes... no Failed commandline was: -------------------------------------------------- gcc conftest.c -Wall -I. -I$(SRCPATH) -I../l-smash/tmpbuild/include -D_POSIX_C_SOURCE=200112L -Werror=unknown-attributes -L../l-smash/tmpbuild/lib -o conftest cc1.exe: error: '-Werror=unknown-attributes': no option -Wunknown-attributes -------------------------------------------------- Failed program was: -------------------------------------------------- int main (void) { return 0; } -------------------------------------------------- checking for -Werror=attributes... yes checking for -Werror=ignored-attributes... yes checking for -lshell32... yes checking whether windres works... yes checking whether !WINAPI_FAMILY_PARTITION(WINAPI_PARTITION_DESKTOP) is true... no -------------------------------------------------- conftest.c:1:10: fatal error: winapifamily.h: No such file or directory 1 | #include <winapifamily.h> | ^~~~~~~~~~~~~~~~ compilation terminated. -------------------------------------------------- Failed program was: -------------------------------------------------- #include <winapifamily.h> #if !(!WINAPI_FAMILY_PARTITION(WINAPI_PARTITION_DESKTOP)) #error #endif -------------------------------------------------- x264 configure script Command line options: "--enable-shared" "--enable-static" "--bit-depth=8" "--extra-cflags=-I../l-smash/tmpbuild/include" "--extra-ldflags=-L../l-smash/tmpbuild/lib" checking whether gcc works... yes checking whether gcc supports for( int i = 0; i < 9; i++ ); with -std=gnu99... yes checking whether gcc supports __attribute__((force_align_arg_pointer))... yes checking for -mpreferred-stack-boundary=6... yes checking whether nasm supports vmovdqa32 [eax]{k1}{z}, zmm0... yes checking whether gcc supports __asm__("pabsw %xmm0, %xmm0");... yes checking for volatile float x = 2; return log2f(x); in math.h... yes checking for strtok_r(0, 0, 0); in string.h... yes checking for clock_gettime(CLOCK_MONOTONIC, 0); in time.h... yes checking for packages: libswscale libavutil... no Failed commandline was: -------------------------------------------------- pkg-config --exists libswscale libavutil ./configure: line 266: pkg-config: command not found -------------------------------------------------- checking for sws_init_context(0,0,0); in libswscale/swscale.h... no Failed commandline was: -------------------------------------------------- gcc conftest.c -m32 -Wall -I. -I$(SRCPATH) -I../l-smash/tmpbuild/include -D_POSIX_C_SOURCE=200112L -march=i686 -mfpmath=sse -msse -msse2 -std=gnu99 -D_GNU_SOURCE -mpreferred-stack-boundary=6 -Werror=attributes -Werror=ignored-attributes -lswscale -lavutil -lshell32 -m32 -L../l-smash/tmpbuild/lib -Wl,--large-address-aware -Wl,--dynamicbase,--nxcompat,--tsaware -o conftest conftest.c:1:10: fatal error: libswscale/swscale.h: No such file or directory 1 | #include <libswscale/swscale.h> | ^~~~~~~~~~~~~~~~~~~~~~ compilation terminated. -------------------------------------------------- Failed program was: -------------------------------------------------- #include <libswscale/swscale.h> int main (void) { sws_init_context(0,0,0); return 0; } -------------------------------------------------- checking for packages: libavformat libavcodec libavutil... no Failed commandline was: -------------------------------------------------- pkg-config --exists libavformat libavcodec libavutil ./configure: line 266: pkg-config: command not found -------------------------------------------------- checking for -lavformat... no Failed commandline was: -------------------------------------------------- gcc conftest.c -m32 -Wall -I. -I$(SRCPATH) -I../l-smash/tmpbuild/include -D_POSIX_C_SOURCE=200112L -march=i686 -mfpmath=sse -msse -msse2 -std=gnu99 -D_GNU_SOURCE -mpreferred-stack-boundary=6 -Werror=attributes -Werror=ignored-attributes -lavformat -lshell32 -m32 -L../l-smash/tmpbuild/lib -Wl,--large-address-aware -Wl,--dynamicbase,--nxcompat,--tsaware -o conftest c:/mingw/bin/../lib/gcc/mingw32/9.2.0/../../../../mingw32/bin/ld.exe: cannot find -lavformat collect2.exe: error: ld returned 1 exit status -------------------------------------------------- Failed program was: -------------------------------------------------- int main (void) { return 0; } -------------------------------------------------- checking for av_register_all(); in libavformat/avformat.h... no Failed commandline was: -------------------------------------------------- gcc conftest.c -m32 -Wall -I. -I$(SRCPATH) -I../l-smash/tmpbuild/include -D_POSIX_C_SOURCE=200112L -march=i686 -mfpmath=sse -msse -msse2 -std=gnu99 -D_GNU_SOURCE -mpreferred-stack-boundary=6 -Werror=attributes -Werror=ignored-attributes -lshell32 -m32 -L../l-smash/tmpbuild/lib -Wl,--large-address-aware -Wl,--dynamicbase,--nxcompat,--tsaware -o conftest conftest.c:1:10: fatal error: libavformat/avformat.h: No such file or directory 1 | #include <libavformat/avformat.h> | ^~~~~~~~~~~~~~~~~~~~~~~~ compilation terminated. -------------------------------------------------- Failed program was: -------------------------------------------------- #include <libavformat/avformat.h> int main (void) { av_register_all(); return 0; } -------------------------------------------------- checking for packages: ffms2... no Failed commandline was: -------------------------------------------------- pkg-config --exists ffms2 ./configure: line 266: pkg-config: command not found -------------------------------------------------- checking for FFMS_DestroyVideoSource(0); in ffms.h... no Failed commandline was: -------------------------------------------------- gcc conftest.c -m32 -Wall -I. -I$(SRCPATH) -I../l-smash/tmpbuild/include -D_POSIX_C_SOURCE=200112L -march=i686 -mfpmath=sse -msse -msse2 -std=gnu99 -D_GNU_SOURCE -mpreferred-stack-boundary=6 -Werror=attributes -Werror=ignored-attributes -lffms2 -lshell32 -m32 -L../l-smash/tmpbuild/lib -Wl,--large-address-aware -Wl,--dynamicbase,--nxcompat,--tsaware -o conftest conftest.c:1:10: fatal error: ffms.h: No such file or directory 1 | #include <ffms.h> | ^~~~~~~~ compilation terminated. -------------------------------------------------- Failed program was: -------------------------------------------------- #include <ffms.h> int main (void) { FFMS_DestroyVideoSource(0); return 0; } -------------------------------------------------- checking for FFMS_DestroyVideoSource(0); in ffms.h... no Failed commandline was: -------------------------------------------------- gcc conftest.c -m32 -Wall -I. -I$(SRCPATH) -I../l-smash/tmpbuild/include -D_POSIX_C_SOURCE=200112L -march=i686 -mfpmath=sse -msse -msse2 -std=gnu99 -D_GNU_SOURCE -mpreferred-stack-boundary=6 -Werror=attributes -Werror=ignored-attributes -lffms2 -lstdc++ -lshell32 -m32 -L../l-smash/tmpbuild/lib -Wl,--large-address-aware -Wl,--dynamicbase,--nxcompat,--tsaware -o conftest conftest.c:1:10: fatal error: ffms.h: No such file or directory 1 | #include <ffms.h> | ^~~~~~~~ compilation terminated. -------------------------------------------------- Failed program was: -------------------------------------------------- #include <ffms.h> int main (void) { FFMS_DestroyVideoSource(0); return 0; } -------------------------------------------------- checking for packages: liblsmash... no Failed commandline was: -------------------------------------------------- pkg-config --exists liblsmash ./configure: line 266: pkg-config: command not found -------------------------------------------------- checking for lsmash_destroy_root(0); in lsmash.h... yes checking whether LSMASH_VERSION_MAJOR > 1 || (LSMASH_VERSION_MAJOR == 1 && LSMASH_VERSION_MINOR >= 5) is true... yes checking for uint32_t test_vec __attribute__ ((vector_size (16))) = {0,1,2,3}; in stdint.h... yes checking for -fno-tree-vectorize... yes checking for -fno-zero-initialized-in-bss... yes checking for fseeko(stdin,0,0); in stdio.h... no Failed commandline was: -------------------------------------------------- gcc conftest.c -O3 -ffast-math -m32 -Wall -I. -I$(SRCPATH) -I../l-smash/tmpbuild/include -D_POSIX_C_SOURCE=200112L -march=i686 -mfpmath=sse -msse -msse2 -std=gnu99 -D_GNU_SOURCE -mpreferred-stack-boundary=6 -fomit-frame-pointer -fno-tree-vectorize -fno-zero-initialized-in-bss -Werror=attributes -Werror=ignored-attributes -llsmash -lshell32 -m32 -L../l-smash/tmpbuild/lib -Wl,--large-address-aware -Wl,--dynamicbase,--nxcompat,--tsaware -o conftest conftest.c: In function 'main': conftest.c:2:19: warning: implicit declaration of function 'fseeko'; did you mean 'fseek'? [-Wimplicit-function-declaration] 2 | int main (void) { fseeko(stdin,0,0); return 0; } | ^~~~~~ | fseek c:/mingw/bin/../lib/gcc/mingw32/9.2.0/../../../../mingw32/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\cc4rp7W6.o:conftest.c:(.text.startup+0x23): undefined reference to `fseeko' collect2.exe: error: ld returned 1 exit status -------------------------------------------------- Failed program was: -------------------------------------------------- #include <stdio.h> int main (void) { fseeko(stdin,0,0); return 0; } -------------------------------------------------- checking for fseeko64(stdin,0,0); in stdio.h... yes checking for -Wshadow... yes checking for -Wmaybe-uninitialized... yes checking for -fvisibility=hidden... yes platform: X86 byte order: little-endian system: WINDOWS cli: yes libx264: internal shared: yes static: yes asm: yes interlaced: yes avs: avisynth lavf: no ffms: no mp4: lsmash gpl: yes thread: win32 opencl: yes filters: crop select_every lto: no debug: no gprof: no strip: no PIC: no bit depth: 8 chroma format: all -
This one has just worked for me:
(after compiling L-Smash (64-bits), bien entendu)
./configure --host=x86_64-pc-mingw32 --enable-static --disable-opencl --bit-depth=all --enable-strip --disable-swscale --disable-lavf --disable-ffms --disable-gpac --extra-cflags="-I./z/include" --extra-ldflags="-L./z/lib"
make
— with "z" = a subdirectory of the x264 source-code directory, containing "include/lsmash.h", "lib/liblsmash.a" and "lib/pkgconfig/liblsmash.pc" —
Final result:
=> x264 --help
x264 core:161 r3015 4c2aafd
Syntax: x264 [options] -o outfile infile
Infile can be raw (in which case resolution is required),
or YUV4MPEG (*.y4m),
or Avisynth if compiled with support (yes).
or libav* formats if compiled with lavf support (no) or ffms support (no).
Outfile type is selected by filename:
.264 -> Raw bytestream
.mkv -> Matroska
.flv -> Flash Video
.mp4 -> MP4 if compiled with GPAC or L-SMASH support (lsmash)
Output bit depth: 8/10
But if you want a 32-bit executable, you'll need a 32-bit L-Smash library and then use --host=i686-pc-mingw32 in x264's ./configure.
Hope this helps
Ok, it looks like I got the build, but I'm curious about those other errors it seems ignored them.
BTW, why does the compiled have less file size than the official release build?Code:checking for -Werror=unknown-warning-option... no Failed commandline was: -------------------------------------------------- gcc conftest.c -Wall -I. -I$(SRCPATH) -I../l-smash/tmpbuild/include -D_POSIX_C_SOURCE=200112L -Werror=unknown-warning-option -L../l-smash/tmpbuild/lib -o conftest cc1.exe: error: '-Werror=unknown-warning-option': no option '-Wunknown-warning-option' -------------------------------------------------- Failed program was: -------------------------------------------------- int main (void) { return 0; } -------------------------------------------------- checking for -Werror=unknown-attributes... no Failed commandline was: -------------------------------------------------- gcc conftest.c -Wall -I. -I$(SRCPATH) -I../l-smash/tmpbuild/include -D_POSIX_C_SOURCE=200112L -Werror=unknown-attributes -L../l-smash/tmpbuild/lib -o conftest cc1.exe: error: '-Werror=unknown-attributes': no option '-Wunknown-attributes'; did you mean '-Wno-attributes'? -------------------------------------------------- Failed program was: -------------------------------------------------- int main (void) { return 0; } -------------------------------------------------- checking for -Werror=attributes... yes checking for -Werror=ignored-attributes... yes checking for -lshell32... yes checking whether windres works... yes checking whether !WINAPI_FAMILY_PARTITION(WINAPI_PARTITION_DESKTOP) is true... no -------------------------------------------------- conftest.c:3:2: error: #error 3 | #error | ^~~~~ -------------------------------------------------- Failed program was: -------------------------------------------------- #include <winapifamily.h> #if !(!WINAPI_FAMILY_PARTITION(WINAPI_PARTITION_DESKTOP)) #error #endif -------------------------------------------------- x264 configure script Command line options: "--host=i686-pc-mingw32" "--enable-static" "--disable-opencl" "--bit-depth=all" "--enable-strip" "--disable-swscale" "--disable-lavf" "--disable-ffms" "--disable-gpac" "--extra-cflags=-I../l-smash/tmpbuild/include" "--extra-ldflags=-L../l-smash/tmpbuild/lib" checking whether gcc works... yes checking whether gcc supports for( int i = 0; i < 9; i++ ); with -std=gnu99... yes checking whether gcc supports __attribute__((force_align_arg_pointer))... yes checking for -mpreferred-stack-boundary=6... yes checking whether nasm supports vmovdqa32 [eax]{k1}{z}, zmm0... yes checking whether gcc supports __asm__("pabsw %xmm0, %xmm0");... yes checking for volatile float x = 2; return log2f(x); in math.h... yes checking for strtok_r(0, 0, 0); in string.h... yes checking for clock_gettime(CLOCK_MONOTONIC, 0); in time.h... yes checking for packages: liblsmash... no Failed commandline was: -------------------------------------------------- pkg-config --exists liblsmash -------------------------------------------------- checking for lsmash_destroy_root(0); in lsmash.h... yes checking whether LSMASH_VERSION_MAJOR > 1 || (LSMASH_VERSION_MAJOR == 1 && LSMASH_VERSION_MINOR >= 5) is true... yes checking for uint32_t test_vec __attribute__ ((vector_size (16))) = {0,1,2,3}; in stdint.h... yes checking for -fno-tree-vectorize... yes checking for -fno-zero-initialized-in-bss... yes checking for fseeko(stdin,0,0); in stdio.h... yes checking for -Wshadow... yes checking for -Wmaybe-uninitialized... yes checking for -fvisibility=hidden... yes platform: X86 byte order: little-endian system: WINDOWS cli: yes libx264: internal shared: no static: yes asm: yes interlaced: yes avs: avisynth lavf: no ffms: no mp4: lsmash gpl: yes thread: win32 opencl: no filters: crop select_every lto: no debug: no gprof: no strip: yes PIC: no bit depth: all chroma format: all -
No clue which releases count as official.
Wild guess: at least lavf and ffms are usually included, sometimes even opencl support.users currently on my ignore list: deadrats, Stears555, marcorocchini -
Well, I have no idea of why you got those error messages
For what it's worth... I don't use Windows 10 and my MSYS2 setup doesn't use the GCC stuff provided by the MSYS2 servers (through pacman.exe),
my GCC package is Windows-threaded and it is built through the script(s) written by Zeranoe and modified by nevcairiel.
https://files.1f0.de/mingw/scripts/
EDIT:
presuming your GCC is posix-threaded, try adding the option --disable-win32thread and see if this makes some difference...Last edited by El Heggunte; 4th Jul 2020 at 19:11.
I think begin to understand.
I also understand the reason why it doesn't recommend compile with GPAC, but it doesn't hurt to learn that too. I built the gpac static lib and added --extra-cflags="-I../gpac/tmpbuild/include/gpac" --extra-ldflags="-L../gpac/tmpbuild/lib" --extra-ldflags="-L../gpac/bin/gcc" to ./configure line but for some reason x264 says "mp4: no". -
No clue.
I usually use MBAS (https://github.com/m-ab-s/media-autobuild_suite) to build x264 and other tools, you might want to take a look at their build scripts.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
In the Last year i tried to use that but always show errors and wasted time.
Going back to the topic, x264's config.log file says one of the errors that GPAC undetectable is because it can't find "gpac/tmpbuild/include/gpac/isomedia.h". I don't understand how that file could not be generated if apparently my GPAC build didn't show errors. Newer GPAC versions no longer generate that file or what?
EDIT:
I already know how to get GPAC to be detected, also in the most recent versions of x264 source code you can compile it with the most current version of GPAC. Just copy the GPAC header to x264 using "cp -R ../gpac/tmpbuild/include/gpac ." before going to ./configure line.
Just one more doubt. How do I compile with libav or lavf?Last edited by naoto89; 9th Jul 2020 at 12:59.
@naoto69: congrats for finding out how to include GPAC's muxer (mp4box) in x264.
Well, as I said before, GPAC is bloatware, takes ages to compile, it contains much more than MP4Box, etc., whereas L-Smash is just and only an MP4 muxing library, therefore...I also understand the reason why one doesn't recommend compile with GPAC, but it doesn't hurt to learn that too.
Also, GPAC is a project maintained by Linux zealots/TROLLS
— therefore...
Why the x264 devs still haven't included an MP4 muxer in their source-code is beyond me
Why having "native" Matroska and FLV muxers is okay but a "native" MP4 muxer is not?
Hope someone who knows more than I do will chime inJust one more doubt. How do I compile with ffms or lavf?
Based on what I read, FFmpeg must be compiled for load "libavformat" and even "swscale" on x264.
I thought just putting that "--extra-cflags=-I../ffmpeg/tmpbuild/include --extra-ldflags=-L../ffmpeg/tmpbuild/lib" was enough, but it seems not.
EDIT:
When compile FFmpeg with
This message appears in yellow.Code:./configure --prefix=tmpbuild --disable-network --disable-debug --disable-yasm --enable-gpl --enable-libx264 --enable-static --extra-cflags=-I./tmpbuild/include --extra-ldflags='-L./tmpbuild/lib -static' --extra-cflags=-I../x264/tmpbuild/include --extra-ldflags=-L../x264/tmpbuild/lib && make && make install
But if I add "--enable-shared" to ./configure line, this error appears.Code:WARNING: using libx264 without pkg-config
I looked for some solution, but it's not related to this. I feel like 2 errors but I have no idea what cause is or what I did wrong.Code:C:/msys64/mingw32/bin/../lib/gcc/i686-w64-mingw32/10.1.0/../../../../i686-w64-mingw32/bin/ld.exe: libavcodec/bintext.o:bintext.c:(.text.unlikely+0x149): undefined reference to `_imp__avpriv_cga_font' C:/msys64/mingw32/bin/../lib/gcc/i686-w64-mingw32/10.1.0/../../../../i686-w64-mingw32/bin/ld.exe: libavcodec/bintext.o:bintext.c:(.text.unlikely+0x153): undefined reference to `_imp__avpriv_vga16_font' C:/msys64/mingw32/bin/../lib/gcc/i686-w64-mingw32/10.1.0/../../../../i686-w64-mingw32/bin/ld.exe: libavcodec/tmv.o:tmv.c:(.text+0x16f): undefined reference to `_imp__avpriv_cga_font' collect2.exe: error: ld returned 1 exit status make: *** [ffbuild/library.mak:103: libavcodec/avcodec-58.dll] Error 1
Correct color output for DVDR-VHS to x264 conversion
By mrwhitethc in forum Video ConversionReplies: 19Last Post: 18th Feb 2020, 22:10 -
Vegas to x264 mp4 with vfr - what's the best way to do it?
By Srivas in forum EditingReplies: 11Last Post: 2nd Sep 2018, 23:11 -
How do I convert a 20GB MKV file to a smaller x264 MP4?
By R.STEED in forum Blu-ray RippingReplies: 11Last Post: 9th Jan 2017, 15:08 -
Want to add subs to an mp4
By Zahnadu in forum SubtitleReplies: 12Last Post: 30th May 2016, 13:00 -
Compile aborting during compile of DVR stream in DVD Lab Pro
By Xoanon in forum Authoring (DVD)Replies: 2Last Post: 18th Jan 2016, 14:43
