Results 1 to 13 of 13
You want to record something on the PC to a VHS tape?
See if there is anything in this thread that may help
https://forum.videohelp.com/threads/377489-How-can-I-record-from-the-computer-to-vhs-tape -
Short answer: No
Longer answer: A VCR requires an analog signal to tune in to a defined channel (US guys can confirm the appropriate ones since ours are different)
What might be possible, depends on your tv, is to use it as a monitor and connect a D-connector to it from a video-out on your video card on the pC or an hdmi cable from your video card to hdmi on the tv. -
So you actually have a tv with built-in vcr.
Someone may correct me here but this unit is analog only. That converter box appears to accept hdmi and output RCA but there is no indication of any digital to analog conversion. And in that scenario it will not work for you. -
Ok. My bad. Yes. Composite is an analog signal.
You will still have the issue of providing power to the converter.
So it might work. I just fail to see what you gain by doing this. -
Page 24 of the manual shows which input is for audio. Audio on the converter is red and white. So it's just a simple trial and error which one works (both should)
If I wanted to record my computer screen on my VCR, I would use one of my computers that has HDMI, DVI, or Displayport output. I would then connect this to the HDMI input on my Denon receiver. Like many receivers, it can convert input signal into many formats. On my AVR-3311 this includes the ability to convert HDMI to composite NTSC video. So, all I'd need to do is press "record" on my VCR and it will record whatever is being fed into the Denon receiver.
A Blu-Ray player & VCR connected together, VCR input settings?
By Kzzrn in forum Newbie / General discussionsReplies: 6Last Post: 28th Dec 2019, 10:15 -
Both VCR's no picture, only sound after playing a VHS-C tape
By videotardis in forum MediaReplies: 20Last Post: 2nd Jul 2018, 19:20 -
Betamax VCR have problems playing prerecorded tapes.
By digicube in forum Capturing and VCRReplies: 10Last Post: 1st Mar 2017, 13:58 -
VCR not playing tapes from beginning
By danda in forum Newbie / General discussionsReplies: 9Last Post: 20th Jul 2016, 12:42 -
VCR playing tapes too fast - but not all the time
By Brainiac in forum MediaReplies: 3Last Post: 30th Dec 2015, 19:41
