    Nov 2002
    Australia
    had a system crash. new disk, new install. forgotten all about how I did this, did that, installed this, installed that.
    Win10
    downloaded youtube-dl. Put it in a folder of it's own. Put that folder in the path.
    Now I can go to powershell and write youtube-dl and it will not object. It will just make a new prompt.
    Just as though it had carried out a command and moved to a newline.
    I give it an URL or I give it "-U", same thing. Just makes a new prompt and waits for me.
    What have I done wrong or failed to do?
  2. first run cmd. then write youtube-dl link like this
    youtube-dl https://www.youtube.com/watch?v=7sbbb7Dt3D8
    you must open the cmd from the path where is yt-dl, ex:
    C:\youtube-dl>
    Nov 2002
    Australia
    It's working this morning. Don't know why. Your example is how I've always done it - probably should have explained that I've been using it for a long time quite successfully.
    Perhaps windows needed to be shut down and restarted for it to become aware of the path changes I made?
    Anyway, It's working again. thanks for your help.
  4. Originally Posted by lomero View Post
    first run cmd. then write youtube-dl link...
    Then why did you type:
    Now I can go to powershell and write youtube-dl...
    Nov 2002
    Australia
    I wonder if we're on the same page here. I said I type 'youtube-dl' and get a new prompt to signify that I don't get that error message from youtube-dl telling us to supply an URL, etc... all that stuff.
    Nor did I get an error from powershell saying the command was not understood.
    I just quietly got a new prompt. That's strange behaviour to me - I mean I'm not used to it - I didn't (and don't) know what it signified.
  6. Perhaps windows needed to be shut down and restarted for it to become aware of the path changes I made?
    no.
    and powershell it's not needed. run cmd then yt-dl from its path. stop
    Nov 2002
    Australia
    I don't see the point. It's just as much hassle for me to run cmd as run powershell. Powershell IS my 'cmd' now and has been for a couple of years I guess.
    And this is the way I've always done it and was perfectly happy with it.... I think I will stick with it.
    thanks for your input.
  8. Show the picture.
